Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
Now where do I get a roof for this place? I don't think I have enough lumber.
cheers,
dr geep ... :o]
edited 10/5/2019
What you have to do is tile the texturemap, and adjust the U and V scales to suit. Using the UV map I'v made for the garage, the V-scale is about 0.1420 and the U-scale is 0.07150
I shall have to measure a brick, make a block, and use it a gauge.
Tweak the V-offset to get a mortar-line matching the top edge of the doors. On a real brick building, the wall goes into the ground, but builders don't like untidy tops to doors.
And now back to the Doc...
It is a 160 x 136 .gif (only 2KB)
cheers,
dr geep
;=] edited because it's ... (actually it's only 1.9KB) <----------- who cares ;=]
Message edited on: 08/25/2004 23:34
cheers,
dr geep ... :o]
edited 10/5/2019
Way back, when we were working in our various ways on the garage, you described how to set up the materials. It looks as though the outer wall surface of the garage should be split into three sections. Front and one side for the outside wall, and the other two as seperate surfaces, since they face onto different rooms.
Aw, you musta peeked at Page 21 ... no? ... ;=] If you didn't peek, you'll find the correct answer on Page 21 if you CLICK HERE. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
