Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 11:30 pm)
I pull it into UVMapper, then choouse new planar map. It still stays messed up. Too many lines. Looks like garbage. Ihave used UVMapper for other things, and it has worked well. Just not this. IT is my first experience at something with objects attached. I have deleted as many objects as possible, even gone into Carrara, and deleted from the 3DS model, then exported as OBJ. It seems like so much work, and still isn't helping me. Does anyone know Wyrmmaster? Or one of the other guys who has used Bladewoman? I just want a skin template for her.
Ok, I have tried that. The map is really messed up. I deleted the hair, and the costume, till I have just the figure left. I can put a map on that ok. Problem is now that I have an object that when put back into Poser, will not work with the character. The costume is built around her figure. I try to turn the figure invisible, but parts of the costume dissappear. Would you be willing to try this yourself, and send me a template for her? Thanks.
I just downloaded BladeWoman and brought the figure up in Poser 4.0.3 + Pro Pack and I found that she is missing "facets" on her head, neck, and legs. You can see right through a few rectangular "holes" in her thighs and head, and a large irregular patch is missing such that you can see the inside of the back of her shoulder. Has anyone had this problem or know how I can fix it?
I figured as much. Well, perhaps I'd be motivated to fix this figure to work with Pro Pack. I exported the figure to 3DStudio Max and examined the surfaces with the errors, and although there are verticies defined in the areas which come up as "holes", there are no surfaces associated with those surfaces in 3DSM. Being a 3DStudioMax neophyte, can someone inform me of how to "patch" those holes?
I think Bladewoman is a cool character. I have tried to apply a map to her skin, but it never matches up properly. I have contaced Wyrmmaster, who made Bladewoman, and he has read my message, but offers no response. Does anyone know what figure she is based on? How to get a skin map on her? Or some utility that will pull a template off of her so I can apply a tex map? Thanks.
