Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 7:10 pm)
I dn't have this particualr outfit but stuff like this is a known prob with GIRL and Poser5. If there aren't any JCM or morphs dials in the top for you to tweak you should be able to fix that with a magnet in about 10mins. Select the specific part of the clothes where you have poke though and create a magnet. Orient the magnet by selecting it's base, position it so the base is roughly intersecting the problem area. Now go and select the mag zone, centre it on the area of pokethrough and scale it down to what seems a reasonable radius. Select the magnet and move it using the positon dials to stretch the top over the breast. You will have to fine tune the size of the mag zone and position of the magnet but it should work ok. When your finished just make all the mag componets invisible in the properties window.
Thank you all for your replies and please excuse my ignorance. Yes, I am using Poser 5. What is a JCM? I did find that by positioning the callor for that breast with a dial, I was able to fix it. However, this still does not explain the situation. if I pose her in various ways, I lose the "strap" of the "bra" in her skin, or th etop of her breast pokes out. I am not profecient enough with magnets to make that work, and I dont know how to use a body handle. :( Is this just how it is or am I missing something? Thanks for all the great responces, you helped me in positioning the collar to fix the issue for the current situation.
JCM = joint controlled morph the earlier millennium figures, such as vicky 1-2, has problems with joints when you posed them. for example, when you raised their arms above their heads, they looked unnatural. a joint controlled morph is a special morph that is controlled by a joint's movement. so now, with vicky 3, when you raise her arms above her head a JCM is gradually applied to lift/stretch her breast up as well, so it looks more natural. an easier example would be a JCM for a bicep muscle. you can create a JCM that will 'flex' a bicep when you bend an arm. as the arm bends, it gradually applies the morph - so slight arm bends result in a slightly flexed bicep, and a full bend results in the full morph. you can find more info on them on nerd's site. an important thing to remember though, is that in order for most JCM clothing to work, the figure you are conforming them to needs to be figure 1. if youre loading another figure first, they wont work... but that wouldnt explain why one boob is conforming and the other isnt, its probably what jim said and one of the breasts is 'posed'. heh, poseable breasts.. now ive seen everything :)
np. yeah i forgot to mention that for every figure that has JCMs in it, the conforming clothing has to match those JCMs in order to conform. this is why its such a joy to make conforming clothing for, say, vicky 3 or stephanie 3 - you have to make morphs on your clothing for all of her JCMs and then code it into the CR2. fun stuff. :(
