Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Attached Link: http://www.uvmapper.com
In UVMapper pro you can select by material, then hit the delete key and its gone. Then use the lasso selection and delete the back of the head. 2 minutes :)https://www.darkelegance.co.uk/
This is what i do (Poser Pro pack) Select the head -go to the "grooping tool" ( the "editing" tool bar) -create a new group (name it as you want) -click on "include material" and select the "Skin Face" material, the "Lips" material, and all you need (eye socket, etc chatever you want. -Each part selected becomes red Now click on the "Create a new prop" button, and that's it. You have your mask.
No problem with anim8or. Import the head Set the view to side view Maximize the view with the eye button Select point editing Take the knife, and make the cut (the new points will be white ones) Take the selector and select all the points you want to remove and push del.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
ok I posted yesterday about trying to remove part of an obj(the back of the head, and other parts to leave basically just the face minus eyes and teeth and all that good stuff) I was directed to a proggy ..anim8.. anyway. it has a cut edge thing. cool...I did a loop cut. BUT....now the heck to I remove the cut part. not only that but the bugger keeps crashing. There is no forum for this program here. and thought hopefully since this si going to be used in poser someone could help me. I am going nuts trying to remove parts so I can use just the face portion..HELLLLLPPP
Commission Closed till 2025
