Fri, Nov 15, 5:58 AM CST
Photography F.A.Q (Last Updated: 2024 Nov 13 3:04 pm)
Subject: No Images..???
jimry ( ) posted Sat, 28 August 2004 at 6:22 PM · edited Fri, 15 November 2024 at 5:47 AM
As from about 9:00pm UK time my browser decided NOT to show thumbs and images here on RR..??? but would allow images on other sites....???? god knows I've pulled all the stops to try to rectify but to no avail...AARRGGHHHHHHHH...so my aplogies for any comments missing as I just cannot see any thumbs or images... :( atm
Tedz ( ) posted Sat, 28 August 2004 at 6:45 PM
I am more a Freak than a Geek...but, I wonder does it have something to do with the intended "Release" of a "Super Patch", by the Micro Dotty Company, for all the on going problems with Internet Explorer. I read that this "Patch" would become available on the 28th. of August, 2004, through the Micro Dotty Download Center. However, I have also read other views, that if Internet Explorer was a Car, it should have gone to the Wreckers long ago....and, Security Advisor's are suggesting...."Get another Browser". Cheers....but, take nothing as Gospel....it is just what I read :]
3DGuy ( ) posted Sat, 28 August 2004 at 7:08 PM
What browser are you using jim?
What is a friend? A single soul dwelling in two bodies. - Aristotle
-= Glass Eye Photography =- -= My Rendo Gallery =-
jimry ( ) posted Sat, 28 August 2004 at 7:10 PM
sad to say BUT IE6 I guess its a virus myself??....Still pulling out all the stops but..Nothing.
Polski ( ) posted Sat, 28 August 2004 at 7:36 PM
I have the same problem!No images at any Renderosity gallery,but I see images at tutorials or any other places and no problem outside of Renderosity.It happened several days ago. Wojtek..................
DJB ( ) posted Sun, 29 August 2004 at 12:13 AM
I think anyone that got SP2 is having that problem.But I do notice it more in RR.
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
jimry ( ) posted Sun, 29 August 2004 at 4:44 AM
No SP2 Doug...just SP1 and updates...anyway...just d/l'd Netscape 7.2...working ok , can actualy see images..yippee. Not really a Netscape fan but will have to do until I can get IE6 fixed (if I can)..!
3DGuy ( ) posted Sun, 29 August 2004 at 7:47 AM
I'd ditch Netscape and use mozilla. Basically the same, but you get spared the superfluous addons etc.
LostPatrol ( ) posted Sun, 29 August 2004 at 9:42 AM
Attached Link: http://support.microsoft.com/?kbid=283807
Try this I offer advice on a tech forum and this is a common problem with many users with IE6 Most cases the problem is fixed by following the advice in the link. Some settings can change when adding security updates, this issue can occur with or without the new SP2 upgrade to XP
The Truth is Out There
Polski ( ) posted Sun, 29 August 2004 at 12:30 PM
Hello! Thanks for a link.I went through all options(even registry)but it did not help. I know one thing.When I check properties of any "dead" image I see this Type:Not Available Image size:Not Available Created:Not Available Modified:Not Available. Greetings.........Wojtek.........
jimry ( ) posted Sun, 29 August 2004 at 12:40 PM
Found a worm...w32usb2.exe...so much for Norton..!! http://www.sophos.com.au/virusinfo/analyses/w32forbotl.html Not sure if THAT did the corruption in IE ?? ok with Netscape now its config'ed...
LostPatrol ( ) posted Sun, 29 August 2004 at 2:31 PM
jimry Norton like any software is not 100% and some things may get through, I think you will find that what does get through will be picked up in a full system scan, as far as I am told w32usb2.exe can turn off your anti virus software. w32usb2.exe is a new worm and there have only been definitions for it for it since 27/08 Polski If you are getting "Not available" messages then I suspect that the file in question is not there or has a broken link. As people have said that they notice it more on RR than other sites maybe the problem may be a temporary RR server issue that affects IE6 (html is a complex thing and inconsistencies can occur between different browsers) As a foot note this is not an SP2 specific issue I have had SP2 since its release and personally have had no issues. All this of course in just my opinion
Haroon ( ) posted Mon, 30 August 2004 at 8:31 AM
Normally it helps to clean the cache of InternetExplorer. It did with me ;-)
Wojteg ( ) posted Mon, 30 August 2004 at 2:35 PM
Hello! Sometimes simple solution is very hard to find! I called today to Renderosity and they sent me e-mail about my problem: Subject:Red X problem Try the following, it usually clears these kinds of problem up: Log off from the site and close your browser. Check that your computer's time and date are correctly set. Restart your browser, delete all cookies and then come back and log into the site again. 99% of the time this will clear the red X problem. Thank you, Stacey Renderosity Store It happened that my date was incorrect! Now everythings is fine. Thank You all for help anyway! Greetings...............Wojtek........
dark_storm ( ) posted Mon, 30 August 2004 at 3:50 PM
Hello. Never had this problem with my explorer browser before, but im using another browser called: Mozilla Firefox. This is a very good one. You can download it at: http://www.mozilla.org/products/firefox/ . This is a freeware. I hope it will help. Regards, Beno -snootligh-
