The methode to build a IT-A-01 complete is - choose one IT-A-01 figure (head, ...) - unparent all the prop IT-A-01 prop - load another IT-A-01 figure (leg,..) - parent the props to the new figure Warning: never move the unparented props Unparent or "give you NO Parent to this props" means: - select the prop - select "change parent" (I don't remember the menu!) - select "none" That's it! Because if you delete a figure with parented props, the props are deleted Hope it helps.
As I saw andygraph's wonderfull marksmannship at the MP, I knew I had to buy it. But as I unpacked it and checked the content I was more than just confused.
So I checked this forum, to see if there's a tutorial, or something similiar, that would simplify the construction of the cyborg from the four different parts.
I found andygraph's tutorial but to be honest, I never was really into this whole parent-thingy. So I write those lines, with the hope, that there is somebody out there, that could describe the whole construction process, right from the start, up to the finished cyborg to me. I think I'll need an extra lesson in "parenting" Poser parts too ;).
So any help is appreciated.
Thank you very much.
Message edited on: 08/08/2004 18:03
