Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 30 4:51 pm)
Wizzie - set the no. of frames for the DYNAMIC calculation to 0. Drape frames are added BEFORE the dynamic calculations, so you can think of them as "negative" frames. Meaning that if you have a set-up with 10 draping frames and 10 dynamic frames, you'll get a total of twenty frames...10 of which (the draping ones) are never able to be seen, except during the draping process. Cheers, Diolma
Ok, I created a pair of dynamic stockings, setup the right parent (i guess Hip). It Loads well but when i go to the cloth room i get this problem: I set up a key frame and pose at key 10, set the simulation to go from key 1->10 and the drasping from pose 0 and up to key 10. Then i clothify the stockings against the body. When i calculate the draping or simulation it doesnt stop the draping at key 10 it just continues on its own. Any Ideas??
