Mon, Jan 27, 7:06 AM CST
Subject: Pro' Camera - free - of course !
geralday ( ) posted Wed, 01 September 2004 at 12:55 PM · edited Mon, 27 January 2025 at 6:58 AM
Attached Link: http://fast3d.co.uk
Not bad for a little file.
Gerald
SWAMP ( ) posted Wed, 01 September 2004 at 1:21 PM
Cool....looks like my "Hassy". Thanks,SWAMP
xantor ( ) posted Wed, 01 September 2004 at 1:27 PM
Thank you!
Luthoricas ( ) posted Wed, 01 September 2004 at 1:28 PM
Thank you!
ford3auss ( ) posted Wed, 01 September 2004 at 4:45 PM
Thank you so very much,,,
dlk30341 ( ) posted Wed, 01 September 2004 at 5:49 PM
Thank you once again! Superb work :)
geep ( ) posted Wed, 01 September 2004 at 5:53 PM
Very nicely done Gerald. Thank you very much. Now, ... if I can just keep it away from NSG ... cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
GothKurlz ( ) posted Wed, 01 September 2004 at 8:27 PM
hey its a medium format like we used in the studio! rock on! TY SO MUCH! ---Essie
AntoniaTiger ( ) posted Thu, 02 September 2004 at 1:20 AM
Yep, and fairly generic. It's not quite like any real MF camera I've seen. But not wildly unlike any of them.
EnglishBob ( ) posted Thu, 02 September 2004 at 4:31 AM
Thank you! Of course we're all very grateful for your freestuff, Gerald, but I sometimes worry that you're reading my mind to see what I want next. So often, one of your new releases makes me think "Aha! Just what I needed!" - and this is one of them. Thinking about it, you'd better keep on with the telepathy; if we get results like this, it will be worth it. Just keep out of the section labelled 'beware of the leopard' and you should be all right. :)
AntoniaTiger ( ) posted Thu, 02 September 2004 at 6:59 AM
Well, I did raise the idea a whilke back, after I'd been fiddling with Gerald's studio set. I'd added a height morph to the lights in that, which was a quick and easy job.
As you can see, I've been doing a little fiddling with this, to give the camera a better approximation to the shape of a Hasselblad. The Russian-made Kiev-88 is a similar shape.
The real thing would need a lot more polygons, or possibly some good texture maps, to get the chromed metal along the corners. Thinking about it, you'd need one texture-map for the diffuse colour, and a similar pattern, in different shades, for the specular colour. (Black is hard to render well...)
AntoniaTiger ( ) posted Thu, 02 September 2004 at 1:38 PM
This might be a better comparison to show what I've done. The real camera is a Russian-made equivalent of the Hasselblad. All my fiddling was done in Anim8or. I suspect I may have extended the back of the model a little too much.
geralday ( ) posted Thu, 02 September 2004 at 3:15 PM
Your modifications look good. All the best, Gerald.
