Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
I've imported OBJ figures from Poser and then converted them to vertex objects so I can modify them with Carrara when I needed to. When you double-click the figure in Carrara, choose EDIT and then choose "Convert to other modeler". Then choose "vertex modeler". Now you can edit your figure.
www.shonner.com
Message edited on: 09/03/2004 02:32
I imported a Poser model (as 3ds) last night. But I guess the quesion is (but it IS a guess) if you can reimport it back to Poser to use it on the posette and use the dials.
I guess that is possible to, but you should not add vertices, and the named polygons should stay named the same through the in and export.
In the end the results of just pulling some things might be better achieved with magnets in Poser.
Creating Poser-material from scratch is also possible in C3, but rigging it in Poser needs a hand book, I think.
Message edited on: 09/03/2004 02:36
I've built objects for Poser in Carrara, rendered Poser objects (mostly figures) in Carrara, and used Carrara to create Poser Morphs. So the short answer is "yes." If this question is in regards to more detail...not having both applications open in front of me at moment I can't provide description or screenshot. Seems that this might be nice to have in the FAQ here? Or does Transposer make the rest of it moot?
in this place write what is possible
http://www.itc.ua/article.phtml?ID=1269&IDw=35&pid=54
(image whis possete head in the modell room from carrara-1) why i can do it in carrara3 ?
Message edited on: 09/03/2004 01:44
