Sun, Feb 9, 2:46 PM CST
Subject: Cant get the hypervue checkbox to be activated in Vue Pro.
HellBorn ( ) posted Thu, 02 September 2004 at 5:59 PM · edited Tue, 04 February 2025 at 8:07 AM
I have not used the hypervue option for almost a year as there where some iniotial problems with it. As the problems should be gone several patches ago I decided to give it a try. I can however not get the hypervue checkbox to activate. It dosent matter if I choose render to file or screen. Any ideas?
Dale B ( ) posted Thu, 02 September 2004 at 9:31 PM
What exactly are you attempting to do? If an animation, you shouldn't be getting any kind of prompt for to screen or file; just the panel to define your codec and set the other animation parameters. If a large image to be split between multiple cows, then you have to define the areas to be rendered. I haven't done this yet, as all of my Vueing has been animation; I do know that if you haven't defined how the image is to be sectioned, then HyperVue will not activate, as there is nothing there for it to bind to.
HellBorn ( ) posted Fri, 03 September 2004 at 5:07 AM
A still was what I had in mind. I do however have a faint memory of hyperrendering a still before without having to setup any sections? OK, I have some homework to do...
lingrif ( ) posted Fri, 03 September 2004 at 6:51 AM
For single images, I never define sections or anything. Using two machines, Hypervue splits the image into four sections automatically. I make sure that the rendercow engine has been started, then start the render.
www.lingriffin.com
Dale B ( ) posted Fri, 03 September 2004 at 9:39 AM
Hmm... Looks like I need to do some playing with this, as well (manual, manual, where is that manual...?).
bonnyclump ( ) posted Fri, 03 September 2004 at 10:15 AM · edited Fri, 03 September 2004 at 10:16 AM
I think you have to render to screen for some odd reason if you are making a still. It makes no sense why hypervue doesn't work with still images that are to render to disk. The pro version has this baby crazy feature too.
Message edited on: 09/03/2004 10:16
XENOPHONZ ( ) posted Fri, 03 September 2004 at 11:23 AM
Yes, you have to render to screen in order to use rendercow. Don't know why. As long as it works, it doesn't really matter.
Something To Do At 3:00AM
HellBorn ( ) posted Fri, 03 September 2004 at 4:18 PM
I found the reson for it not working... The hypervue does not work in combination with Render Area!! It's pretty easy to workaround but is plain stupid...
