Fri, Nov 22, 8:24 PM CST
Subject: What use/good is Carrara 1.1 for a Poser user ?
Riddokun ( ) posted Sun, 05 September 2004 at 8:54 AM ยท edited Fri, 22 November 2024 at 4:04 PM
i just got an older Carrara versio n(1.1) as complete and free in a magazien cover disk i wondered how / if i could use it in anyway in the optic of being aposer user ? what kind of things carrara can hlp me do ? (regarding poser)
pakled ( ) posted Sun, 05 September 2004 at 9:39 AM
not an expert, but I got pretty much the same deal off of a magazine. I was able to create models and export them to Bryce (3ds, I think, possibly .obj), so you might be able to create models and import them into Poser.
Letterworks ( ) posted Sun, 05 September 2004 at 11:22 AM
C 1.1 works reasonably well for making models for Poser. It's the program I started with. It imports .obj files directly and can even work with Poser's tiny natrual scaling (when importing remember to turn off auto scaling, see the Carrara list for such tips). Natuatlly it doesn't have all of the bells and whistles that the newer versions do but it's a reasonable starter program, to me, at least, the vertex room is a natural for working on Poser objects. Good Luck mike
Riddokun ( ) posted Sun, 05 September 2004 at 12:01 PM
and what abotu importing/rendering poser things witih this old version of Carrara ?
Letterworks ( ) posted Sun, 05 September 2004 at 1:01 PM
As I remember C 1.1 can import anything in .obj format (as well as several other) but I don't think there was a Poser native format importer for C 1.1. I would recomment checking thru the archive files in the Cararra forum and in their tutorials section for more info. It's been a while since I've used it and I don't remember all of the details. mike
mateo_sancarlos ( ) posted Sun, 05 September 2004 at 2:42 PM
Importing and rendering poser figures? Import as obj file from a folder containing all the textures, and scale up to 2000% to avoid problems with transparent surfaces.
x2000 ( ) posted Sun, 05 September 2004 at 4:42 PM
Attached Link: Carrara morph creation tutorial
It works well for creating morph targets (which seems to be a problem for a lot of apps). Check out the linked tut for all the how-to info.
