Simulated this by using a sphere of 66 radials the size of the glass. Then the glass ambience is set to 100%. Transparency can control how much light is let through, I left it at 100% transparent.
Notice the softer shadows.
Render time 22:22
Message edited on: 09/07/2004 19:37
1 radial set to 50% softness
Render time 7:35 Given the time difference perhaps a single radial set to soft shadows would be better and achieve the same thing.
Message edited on: 09/07/2004 20:11
Attached Link: http://freespace.virgin.net/hugo.elias/radiosity/radiosity.htm
In conclusion with the current Bryce to get realistic play of light will take a lot of lights and an enourmous amount of render time. I would love to see besides the faster render time that AS says DAZ has planned. The ability of Bryce to do actual radiosity and actually bounce light several times off of objects. I would also like to see a material setting to set the amount of light that material reflects back into the environment. Black surfaces would reflect very little to no energy back into the environment while white ones would reflect maybe 95% back (some is always absorbed by the material).
Interesting thread, Aldaron. I think you'll find that the render time estimate given by Bryce for your TA scene above is a big underestimate. I've noticed with the advanced render options in Bryce5, particularly True Ambience, that the final pass takes an absolute age compared to prediction in complex scenes. I'm currently rendering a scene that was predicted to be about 12 hours, but will actually be more like 36 hours. In your scene you have about 450 shadow casting lights. This is really asking for trouble with True Ambience, and I suspect the render would actually take several weeks to complete. But the main benefit of using True Ambience is to reduce the number of lights needed to fake light bouncing (light arrays and such like). Using the two together misses the point of both, and combines the worst of both worlds. I believe that True Ambience is designed to achieve a similar job to what radiosity engines are designed to achieve, although the specifics of the process are different (and not as effective). I know my views are not popular amongst the forum 'heavyweights', but I maintain my position with good reason. I'll post more on this in a couple of days. As regards materials behaving in the manner that you mention in your last post, Bryce already has them. Under True Ambience (suitably set up) darker materials 'reflect' less light than lighter ones. Black will 'reflect' nothing; white will 'reflect' the most of all.
True PJF but it doesn't "reflect" it back into the scene far enough. The falloff is way too short. Another point is yes I could probably reduce the number of lights needed but not sure I would get the same effect and probably more banding (which you can't see in these renders). Don't get me wrong, I like TA a lot it just doesn't do enough of what I want. I want light to bounce several times and not just in certain circumstances like you thread that you posted some time ago (which I have yet to reproduce). I'll be putting up a render soon of the tube light with a lot fewer lights and soft shadows and compare it to the above.
Aldaron - actually, the sun is NOT a pin-point source. Try this experiment: Go outside on a bright, sunny day, when the sun is at an appreciable angle from the vertical (ie, not local noon). Stand somewhere where you can see your whole shadow. (If that happens to be the middle of a road with lots of fast traffic, I suggest moving the experiment elsewhere..) Now look at your shadow. Near the feet, the shadow will be crisp. As the shadow "moves" up the body it will get less distinct. The further away the surface that recieves the shadow, the less distinct... This is because your body is being hit by light rays from across the whole surface of the sun. Since ALL those rays are straight (not parallel - just straight), where they overlap after passing beyond the your body's edge, the amount of shadow is reduced. Plus, of course, the atmosphere spreads light around too. Which latter is something that many sci-fi artists forget: they are told that "in space (or on the moon) shadows are crisp, because there's no atmosphere". Not so. Although there's no light scattering from atmosphere, if the light source is close enough to be discerned as a disk, there will be shadow softening. The contrast will be much greater though. Errm... I'm rambling.. I'll shut up now... Cheers, Diolma
Wow, a real blast from the past. Proves that ebots will haunt you forever. "We were able to make light bounce with TA, but since there are no TA LIGHTS, per se, it is nearly useless as a tool..." While TA can't help in bouncing hard light off of mirrors, it is far from useless. It "bounces" diffuse light quite well, and in this context all Bryce lights are "TA lights" since they can all provide the initial "energy". True Ambience was only partially developed when Bryce5 was released, and there are quite a few problems with how various objects and surfaces react to it (non-smoothed polygon meshes being notorious). If DAZ can fix those (or some) for Bryce5.5, then True Ambience may see more action. "who I consider a "heavyweight", regardless" If you're calling me a fat git - you're right.
BTW if you wondered where I got the idea for the room.....^Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1445452
LSD, check this thread then tell me Bryce can't bounce light :)This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Attached Link: http://www.wolfiesden.com/bryce/tut/old/adv-lighting3.html
![file_127530.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_127530.jpg)
Since all the talk lately is of lighting in scenes and such I thought I'd do some testing. Wolfie's Den at the link above did a tutorial on lighting in the real world. I decided to replicate these and do some comparisons to real lighting. The first picture is a single radial light, all light calculations are done from a single pinpoint. As far as I know there are no natural or manmade lights sources that only emit light from essentially a point the size of an atom. Notice the hard crisp shadow. This took 33 seconds on a 1.67 Ghz AMD (works like a 2.0 Ghz).
