Sat, Feb 8, 12:16 PM CST
Subject: Can't get skins to load on Ultimate Poser Horse
Shaddex ( ) posted Wed, 08 September 2004 at 1:48 AM · edited Sat, 08 February 2025 at 11:51 AM
I downloaded the Ultimate Poser Horse off of planit 3d, but I can't get textures to load on them at all. I know how to apply textures to models. But I can't get anything to work on these. Eben if I loaded the wrong texture, there was no sign or screwed up texture placeing, it just would not display what so ever. Anyone know what is up with these models?
judith ( ) posted Wed, 08 September 2004 at 2:04 AM · edited Wed, 08 September 2004 at 2:14 AM
If you select the horse and then go to Display/Figure Style from the top menu, you'll find that it's set to "Smooth Shaded" if I remember correctly.
Select "Use Document Style" or "Texture Shaded" from the menu and it should show as you'd like.
Message edited on: 09/08/2004 02:14
What we do in life, echoes in eternity.
E-mail | Renderosity Homepage | Renderosity Store | RDNA Store
Shaddex ( ) posted Wed, 08 September 2004 at 4:33 AM
One more thing, is there away to just set it to make a whole model use all the same settings? It's annoying seting textures to a model that has a LOT of areas.. and changing the texture on each one, one by one is very annoying.. isn't there like an "add to all" option?
xantor ( ) posted Wed, 08 September 2004 at 4:57 AM
If you have poser 5: In the material room go to node options then apply to all.
