make the edge a litle more irregular folowing the stones nice materials
for
some free stuff i made
and
for almost daily fotos
Looks good so far, You can either put a plank with a wood mat, or... some bryce or imported stones as a ledge to sit on. It's not the lighting, so much as the mayang texture does not have the same shadow depth as your other objects in the scene. You can try to darken the material a bit or tweak the sun & or shadow settings in your enviroment. Also if you have an Image editor(photoshop etc) you could touch up around the window in post work to more closely match the wall. Let us know when you're finished. Have Fun ICM
___
Ockham's razor- It's that simple
Green stuff stops too abruptly where the window is cut out. It should grow around the corners a bit.
Thanx every one for the help very much...First of all i'm sorry to post the same message two times...I can'tview my first post,so i post the second time... Thnx for the tut very much...I've tried the bump map but that's not working accurately bcoz i don't know how to make the alpha channel correctly...anyway i'll try it again... ICM says "You can either put a plank with a wood mat, or... some bryce or imported stones as a ledge to sit on" can anyone help me to model or is there any other realistic stones available... i like the 2 volleys of contrat too... Thn again for your help... Varun...:)
![file_128175.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_128175.jpg)
I want some help from you...feel free to your critiques abt this work...work is not completed...i want to put more grass and flowering plants...My prob was abt the window in the wall...the wall is a terrain and texture from mayang...my idea is put a poser woman in the window sitting...
I need to know is there any prob with the edge of the window or do you have any sugestions...
Is the lighting is bad?
Thnx...
varun...:)
