Thu, Nov 14, 9:08 PM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: sprial
hbombblack ( ) posted Sun, 12 September 2004 at 11:34 PM ยท edited Thu, 14 November 2024 at 6:22 PM
I'm at a bit of a dead end here. What i have planned is to make a spiral. I know how to load up the trans map for the material. I made a cyliner, applied the transparency for the material, and rendered it. The spiral does not come out as a continous spiral. Any suggestions on how to fix this. If anyone could post a correct transparency map to use it would be much appreciated.
wabe ( ) posted Mon, 13 September 2004 at 12:48 AM
Can you show an example what goes wrong? And maybe tell what sort of spiral you need? Spiral is an easy to build model, even a sort of primitive in the free version of Cinema 4D. So maybe the easiest would be to model one and send it to you.
hbombblack ( ) posted Mon, 13 September 2004 at 9:51 PM
Here is the transparency map that i used and these are the results that it gave. i very close, i know it.
gnurf ( ) posted Tue, 14 September 2004 at 2:08 AM
You got a common problem there. If you open your map in a graphics application and tile it, you will see that you get the same result (except that it will be in 2D of course :) as in your Vue image. Here's my try that should work:
