Sun, Nov 24, 12:25 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Poser Freezing Problem
MindsEyes ( ) posted Sun, 12 September 2004 at 8:44 PM · edited Sat, 23 November 2024 at 9:57 PM
OK. My girlfriend and i are having some major issues here. Here's the low down on the 2 systems.... Mine: Windows 2k 512mb ram all updates 1.3 amd cpu Nvida gaphics (onboard) Hers: Windows Xp 512mb ram all updates 1.2g p4 64mb nvidia graphics The problem we are having is the same thing. First problem is, Poser keeps freezing soild on us. What i mean is, we don't get the "Not Responding" error. it just stops. mainly when we try and render our images. We are at aloss as of why. problem 2 is this. When we try and load certian items, mainly characters, clothes, etc, from the characters tab, we get an error that read as.... "Poser could not open the "file name" obj. file." when we click ok, we get another message that reads, "You are out of memory." Then it either disposses the last peice we put in, or we loose everything all together. We have gone in and deleted the .rsr file for the obj. and then it will load fine, until we try and load it again. Then it starts all over. I have changed the .rsr file to read only and it still happens. we have gotten all the updates for poser from curious labs. unless we have missed something. anyone know how to fix these problems?
TrekkieGrrrl ( ) posted Mon, 13 September 2004 at 4:30 AM
The "out of Memory" is a generic Poser error message. It basically means "I've given up and am now bucking up. Bye" When Poser can't find an obj file it can't really continue. Sometimes it can but of course without loading the thing that isn't there. If you can pinpoint the errors to some specific items, try reinstalling them. Deleting the rsr usually helps, but if the OBJ is somehow damaged it will just yield a new bad rsr. Oh and since you're mentioning geometry rsr's I assume you have Poser 4?
MindsEyes ( ) posted Mon, 13 September 2004 at 11:18 AM
yes i have poser 4. never upgraded to PP or poser 5. i have taken out the named files. restarted poser, exited it, then reinstalled them. it still happens occasionally. is there away around that "out of memory" bit? i updated to ver4.3 some time ago. and i even tried the memory updater...
TrekkieGrrrl ( ) posted Mon, 13 September 2004 at 12:38 PM
Well the only way around the "out of memory" is to make sure everything is in place. Correct Reference Pro can check all references, even geometry ones. Sometimes it's merely a quiestion of uppercase/lowercase in a filename and Poser can't find it.
