Wed, Dec 25, 10:36 AM CST
Subject: Repairing broken thumbnails
jarm ( ) posted Tue, 06 July 2004 at 2:06 PM ยท edited Tue, 30 July 2024 at 5:37 PM
I moved my runtime to another location, but I suspect some references are screwed as a bunch of thumbnails in my pose folder are not displaying. Anybody know of a utility to whiz through the folders and refresh the thumbnails? Cheers Jody
diolma ( ) posted Tue, 06 July 2004 at 4:09 PM
Hi Jody. I assume you are using P5 (since AFAIK, P4 & previous don't allow you to move runtimes). When you say "are not displaying", do you mean you get the "shrugging man", or just a blank pic (possbly with a circle), or just text? Thumbnails in P5 are .png files. There aren't any references to them; Poser just associates the .png with whichever .pz2 (or cr2 or pp2 or whatever) has the same name. A few checks to make: 1. Use Explorer (or whatever) to ensure that the .png files have been moved together with the pose files. 2. If you have it, try looking at the library using P3DO. The .png files should show up if OK, won't if not. 3. In Poser, apply a relevant pose to a character (or whatever), set up a nice camera angle and add the posed character back into the library (probably under a different name). If the new pose shows up OK, then you have a problem with the .png files. If you are getting just a blank thumb (with or without the circle), the chances are that the .png's alpha channel has been corrupted in the move. If you still have the original library (you DID make a backup before moving, didn't you?..), then try moving (just) the .png files again. Cheers, Diolma
jarm ( ) posted Tue, 06 July 2004 at 4:13 PM
Hi there PNG's are present and look fine in image viewing program, the ones I am missing are primarily mat and partial poses therefore setting up a thumbnail is quite tricky (or at least timeconsuming). Yes I have a backup, but I'm trying to fix this cause it's a bit weird and I haven't seen or heard of Poser doing this before. Best wishes Jody
mask2 ( ) posted Tue, 14 September 2004 at 7:26 AM
I have the same problem: I've just installed a product (from scratch) and Poser (5, SR4.1) just shows blank/circle thumbnails... while if I browse with P3DO the thumbs are just fine... wonderwonder why??? Mario
yarp ( ) posted Tue, 14 September 2004 at 11:56 PM
Attached Link: http://www.senosoft.com/
This is because the alpha channel of the thumb picture is inverted. You can fix this with the P3dO Rsr2Png plugin. Convert from Rsr->Png then from Png->Rsr again (there's an option that will remove the converted RSRs) and all your PNGs will show in Poser. Rsr2Png available in freestuff there and on my website. yarp
Yarp - author of P3DO Organizer for Poser
yarp ( ) posted Tue, 14 September 2004 at 11:57 PM
sorry, I meant "convert from Png->Rsr then from rsr->Png again" ;)
mask2 ( ) posted Sun, 19 September 2004 at 5:31 AM
well, to be honest i've found out what was wrong: seems like poser (at least P5) won't show thumbnails when the total files (.png + .pz2) are in excess of 200... thus i simply divided them in subfolders (files in excess of 200 is easy to achieve when it comes to poses...) do you agree on this?
yarp ( ) posted Sun, 19 September 2004 at 6:47 AM
Absolutely, I thought the limit was 255. I also think, that in latest P5 patch you can change this limit (in LibraryPreference.xls).
