Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:07 am)
Attached Link: http://www.computerarts.co.uk/
Yes, go to the Computer Arts website and you can download a working version. It's a bit of a big download though :-S"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Xantor, look in the forums under the section "Cd problems" or something like that, and look for a thread called "Freak bundle".
"you are terrifying
Shire
Never Mind! I found it.By the way I use Get Right. I have dial up and it's a life saver. Check it out. It's great for huge D/L's. Most sites let you resume The D/L later. You can D/L while you're doing something else, on the computer or even when you're watching TV or something. It can be done a bit at a time, if necessary.
Get right is shareware. I believe they have a fully functional Trial, but with nag screens. I'm not sure, but I think the only restrictions are the nag screens. Of course, they could have changed it, by now. My version is at least 3 years old, but I stiil wouldn't trade it. Oh yes,at this point it doesn't seem to be compatible with AOL 9.0. I use AOL 8.0, when I want to run it. I'm not sure whether there are problems with other ISP's.
OK, I'm dowloading the bundle now. Can any one enlighten me on the following..which was in the CA forum on the bundle - _ "No, we wouldn't expect you to buy the magazine again this month just for the freak. Here it is to download (Warning: It is quite a large file) unzip and then run the freak.exe in the same file as the 020.cab file to install." Whats this 020,cab file they mention ?
Anyone know the difference between the LE and the full version?
So, before I waste a lot of time for nothing, does this include the actual freak figure or not? I have Mike so that's OK, but I didn't buy the freak because I figured I'd have very limited use for it since I already have the Behemoth figure from Sixus, for what little I'd use it. Anyway without the figure of Freak,it isn't worth the time. Does anyone know? Thanks all...
I downloaded the bundle last night. It does not include the actual Freak figure (as that was seperate on the original Computer Arts coverdisc). However, after downloading for 4 hours, hardly anything works. I installed the bundle (using the automatic installer) and nothing went to where it was meant to go. And after spending ages putting all the files where they were meant to be, 90% of the items still don't work! Keep getting error messages (for example: Cannot open Runtime/geometries/ToxicAngel/Freak_armor_top.obj) none of the inj morphs work and even though I can open up a texture and look at it it tells me when I try to render certain textures that they don't exist!!! Think I maybe asking for my money back from Computer Arts as it was the only reason I bought this months issue!!
I haven't tried using the bundle yet after downloading so i will try it tonight and see if I get the same problems. Minty, have you tried running Correct Ref over it? I wonder if it was a paths problem whether the stuff's there but just in the wrong place...
"you are terrifying
Shire
Attached Link: http://www.hogsoft.com/
Correct Ref is a utility made by Hogwarden (Hogsoft). There is a freebie version and a pay for version (here at the MP) which does a lot more. It's a bit pricey at $35 but well worth it if you download a lot of freestuff... like me... and get really annoyed with missing textures, extra .rsr files, bump maps, etc. Anyway the freebie version checks your Poser file paths, ie you point it at a Runtime directory and it will check for missing textures in the files (works for cr2, pz2, pp3 and hr2 files) and you can either point it at the correct file path or set it to not use a map. One of those invaluable utilities that once you start using it, you can't believe you ever got along without it!"you are terrifying
Shire
Hi all. I just popped into the newsagents, bought a copy of this months Computer Arts magazine (It has a FREE copy of 'The Freak LE' and a whole lot of FREAK goodies with it) only to find that the 'FREAK BUNDLE' will not install!!! Has anybody else had any problems with this months CD? Tony.
