Mon, Jan 20, 4:00 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Oh.. I've lost the CircleCam script!
Tiny ( ) posted Mon, 20 September 2004 at 2:42 PM · edited Mon, 20 January 2025 at 11:47 AM
I (apparently) make myself belive I backup everything and always. I have "billions" of backups on CDs and DVDs nicely signed with dates and all.
So what happens now when I need this script specially made by you Ockham? I can't find it on any of my backups! Ok, I've had a few puter crashes since then too, but still!
*bangs her head in the keyboard > asklfhwr iovnac gfrhio
And I even figured out some of it myself. How will I ever get the brain back into that state again?
Is there a slight chance you still have it somewhere laying around in a closet or so....?
sits on floor sobing
Eva
ockham ( ) posted Tue, 21 September 2004 at 10:36 AM
I have the same problem with overenthusiastic housekeeping. In fact, I thought this one was completely lost, until I realized its title is CamCircle, not CircleCam! Finally found it, though. As usual, take the attached text and rename it from .TXT to .PY before using. Incidentally, I like your textual illustration of headbanging!
My python page
My ShareCG freebies
numanoid ( ) posted Tue, 21 September 2004 at 5:36 PM
Um,.... What does this do? Make the camera circle an object?
ockham ( ) posted Tue, 21 September 2004 at 5:46 PM
If I remember right, it turns the camera around at fixed intervals, one frame for each interval. I have no idea why it was wanted.... I just writes 'em, guvnor!
My python page
My ShareCG freebies
Tiny ( ) posted Wed, 22 September 2004 at 5:22 AM · edited Wed, 22 September 2004 at 5:24 AM
:oD
Thanks a million ockham!
..What does this do? ..<<
I need it for my game characters movement. 32 directions almost top down view (a bit like zelda angle). It saves lots of time.
For example, in one part of my game project I have:
10 characters with 4 basic animations (walk, trot, canter, jump)
Each animation have 8 frames
Each frame is rendered in 32 directions
That makes alot of renderings which the CamCircle takes care of! :o) Thanks to ockham. sends hugs to ockham
Message edited on: 09/22/2004 05:24
