Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Yes, I get it too. I have no idea what causes it but it doesn't seem to do any harm.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Hmm, it could be that this pops up after a search window, yes. I shall have to take note of when it appears...
"you are terrifying
Shire
I get that a lot, too, after I've double clicked on a dial once too many times. It doesn't close, and you can't find it. It doesn't lag the program, either...it's just there, LOL.
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
I've had that pop up on occasion as well, and even minimizing all windows and clicking on the "ghost" doesn't do anything. On a side note, closing it has closed Poser itself, and it always goes away when I shut Poser down.
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
Yeah...I get that to alot. Appears from no where after awhile playing in Poser 5, even when you do close the palettes in poser, it is still there. When you right click on it, then "Close"...it also closes Poser and your hard work that you done for the last few hours. I had 4 of em appear one time when I was doing a render.
Hey Ynsaen,
Is there a way to close it without it causing Poser 5 to shutdown?
I agree with the above folks, if you try closing that window it causes Poser 5 to shutdown. Sometimes it opens when I click commands too fast, but then it seems to open for no apparent reason - like when I'm moving the camera using the camera ball.
I don't know for sure if it slows down rendering but it makes you wonder.
Thanks,
Fin
Message edited on: 09/27/2004 02:41
Don't worry about it... it's harmless. It's just one of those things which happens when you write a program for MAC and port it to Windoze (Hehe!). Windows sometimes thinks that the library palette or the prefs window are actually seperate prorgams running and Poser doesn't tell it to hide the taskbar entries. H:))
hogwarden is right, this is not unusual with ports from another platform to Windows. It's the result of sloppy work by the porting programmers, a recompile with a Windows C++ compiler is not enough to convert a Mac (Unix, OS/2, whatever) program into a real Windows program. Same goes for any conversion from one platform to another.
