Woah! Way to go, Vasquez! Many thanks!
vasquez, great LilBot :) love the rustic look about it. I have only one problem with it and it may not be the fault of the model but something i'm not doing or doing in Bryce. I'm new to this so please forgive my stupidness with your model. When i load it to Bryce it is huge, i mean i see from the waist up to the shoulders then thats it. From the waist down it is under the ground plane, the neck and head are somewhere in the clouds. When i shrink it down to fit my screen it all falls apart. So not knowing what to do i thought i would call on the bot maker for help with this problem i have :)
ok lunartrick... some info about my robot... if you press "ctrl" and click over the hip, a list of primitives or groups should appear. Select "HIP", now the hip group should become red, if you click and hold over the red group you are able to move the whole robot around.... ...regarding how to move the camera try a bit with Bryce, and if the manual does not help coem here and I'll happy to help you. vasq
Well, I loaded it up and the same thing happened to me, the model is huge and there is no way to reduce the 'entire' model as one piece to a smaller size without it disingerating into primtive pieces. The hip thing doesn't work to reduce the overall 'size' of the model, it just allows you to move it around the work space as one pc...I know it's easier to model some things 'large' but if you can't change the size to fit the scene it's an exercise in frustration, and you can't use the model no matter how expertly made it is.... Any help would be appreciated, I had a scene in mind to use this guy in, but only if I can make him 'smaller'...
Bryce Forum Coordinator....
Attached Link: http://mio.discoremoto.virgilio.it/vasquezdisk/
ok guys yesterday I made a free account so now I can share with you something. My first freebie is the the old lil' robot I made 1 year ago. Follow the link and download "lilbot.zip". (it's 5mb .obp format) Instructions included. I'ts my first time so please comment and critic it! vasq
