A bendable wire or cable using multi-replicatoin start with creating a path...there are several available to choose from in the create menu. Next you create a metaball and attach it to the path. Multi-replicating the metaball will cause it to follow the path giving you what appears top be a bent cable, rope or wire. That is the gist of it...I am sure you can find a more in depth explanation by searching the forum.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1268129&Form.sess_id=5075165&Form.sess_key=
One thing to beware of when multi-replicating is to be sure to set the X Y and Z scales to 100%, unless you want the replicates to change size. If you've recently scaled or moved the object, make sure to reset 'scale' boxes to 100% (other boxes to zero) before inputting your own instructions.Lots of discussion and examples in recent thread, if you scroll down the attached link.
Message edited on: 09/28/2004 01:36
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
The mat on the smaprtpipe there is just a very slightly tweaked version of the hose.mat from the pack of mats I made up for our July 2003 Challenge. You can find that pack here;
Free Mats
You can get the tweaked version from the render above here;
Download
Here's some renders of the different way the way the hose mat can look if you just wrap it differently;
Link
AgentSmith
Freestuff | IMDB
Credits | Personal
Site
Or, just select metaballs.
Freestuff | IMDB
Credits | Personal
Site
What is it and how is it done? Ive been told this is a way to make cables and wires and such that can bend which ive been trying to do for a while now.
