Sun, Jan 26, 3:49 AM CST
Subject: Multi-Replication
Paintballa198 ( ) posted Mon, 27 September 2004 at 4:31 PM · edited Sun, 26 January 2025 at 3:46 AM
What is it and how is it done? Ive been told this is a way to make cables and wires and such that can bend which ive been trying to do for a while now.
mrscience ( ) posted Mon, 27 September 2004 at 6:56 PM
The above image was done with multireplication of cubes... This image is from my tutorial on a simple introduction to multi-replication in the tutorials section right now... look for the cog thumbnail... good luck
Claymor ( ) posted Mon, 27 September 2004 at 8:10 PM
A bendable wire or cable using multi-replicatoin start with creating a path...there are several available to choose from in the create menu. Next you create a metaball and attach it to the path. Multi-replicating the metaball will cause it to follow the path giving you what appears top be a bent cable, rope or wire. That is the gist of it...I am sure you can find a more in depth explanation by searching the forum.
MoonGoat ( ) posted Mon, 27 September 2004 at 9:43 PM
Multi-replication is a tool that can duplicate an object x times in XYZ dimensions with each copy while rotating it on XYZ axis with each copy. The image was made by multi-reping Just select, edit, multi-replicate, and you're ready to go.
MoonGoat ( ) posted Mon, 27 September 2004 at 9:44 PM
To some, the factor will eventually be recognizeable. Did I spell that right?
Paintballa198 ( ) posted Mon, 27 September 2004 at 10:05 PM
thanks alot everyone... im experimenting with it now
pogmahone ( ) posted Tue, 28 September 2004 at 1:35 AM · edited Tue, 28 September 2004 at 1:36 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1268129&Form.sess_id=5075165&Form.sess_key=
One thing to beware of when multi-replicating is to be sure to set the X Y and Z scales to 100%, unless you want the replicates to change size. If you've recently scaled or moved the object, make sure to reset 'scale' boxes to 100% (other boxes to zero) before inputting your own instructions.
Lots of discussion and examples in recent thread, if you scroll down the attached link.
Message edited on: 09/28/2004 01:36
Gog ( ) posted Tue, 28 September 2004 at 4:12 AM
A quicker way to make cables is to download the smartpipe freebie though......
Toolset: Blender, GIMP, Indigo Render, LuxRender, TopMod, Knotplot, Ivy Gen, Plant Studio.
dan whiteside ( ) posted Tue, 28 September 2004 at 7:41 AM
Seems all MadMax's freebies (like SmartPipe) in Free Stuff are 404. The link I have for MM's D/L's is here: http://www.3dfightclub.com/~madmax/uploads/files/
AgentSmith ( ) posted Tue, 28 September 2004 at 10:31 PM
Love the Bryce Smartpipe. AS
Colette1 ( ) posted Wed, 29 September 2004 at 1:11 AM
Love that texture on the smartpipe AS. :)
AgentSmith ( ) posted Wed, 29 September 2004 at 3:01 AM
The mat on the smaprtpipe there is just a very slightly tweaked version of the hose.mat from the pack of mats I made up for our July 2003 Challenge. You can find that pack here;
Free Mats
You can get the tweaked version from the render above here;
Download
Here's some renders of the different way the way the hose mat can look if you just wrap it differently;
Link
AgentSmith
Colette1 ( ) posted Wed, 29 September 2004 at 9:44 AM
Thanks AS!!!Now to find the link on how to texture the smartpipe, I know the thread is in here somewhere.....
pogmahone ( ) posted Wed, 29 September 2004 at 11:18 AM
yeah, I just asked that question recently. When you've arranged the pipe the way you want, click on the dropdown menu at the bottom, and select the family of the pipe only. then you get the option to add material.
Colette1 ( ) posted Wed, 29 September 2004 at 2:08 PM
Thanks pogmahone. I found the thread.
AgentSmith ( ) posted Wed, 29 September 2004 at 4:36 PM
Or, just select metaballs.
pogmahone ( ) posted Thu, 30 September 2004 at 1:56 AM
SmartPipe is so amazing. I can't even begin to get my head around how he did it :^(
