Sat, Feb 15, 10:30 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 9:24 am)
Subject: UV Mapper tutorail
3dz ( ) posted Wed, 29 September 2004 at 9:01 AM · edited Sat, 15 February 2025 at 10:09 AM
Hello, I was wondering if somebody could help me, I am doing a tutorail for UV mapper. The tutorail is: Customizing Poser clothing - Part 1. How to recreate a moderate size, Hi-Res texture map. by: Renap of FairyWoods<..... "That should of been my frist clue." All was going good, until this part: ***Once again to menu Edit/New Uvmap/Planar this time select the split by orientation option and press OK. You get this distorted map of the sleeves that looks awful - I know- that would produce a terrible stretching map, but dont worry!. We'll fix it later on..*** In the next illustration it shows two arms sleeves selected. The illustration before that only shows one sleeve selected. Throughout the tutorail, it refers you to the next image. Despite all the barriers, I have managed to get to the end of the tutorial. When I checked my preset library, the file name was there, but the thumnail had a grayed out Circle in the middle. (Attached) After awile I figured out this tutorail was made August 15 2000. I'm not sure but, I don't think P5 was released yet. Does anybody know how I can get this to work, or a tutorail for UV mapper that will work for P5? This is a tough one.
PS. Here is a link to the tutorail: http://www.designertoday.com/tabindex-17/tabId-72/itemid-1733/DesktopDefault.aspx
EnglishBob ( ) posted Wed, 29 September 2004 at 9:47 AM
The tutorial should work just as well in Poser 5. There won't be a thumbnail for the new item, but it should open anyway. If you want to get a thumbnail, save the new item back into the library.
neilp ( ) posted Thu, 30 September 2004 at 9:17 AM
Alternatively you could copy the original thumbnail (png) and rename it to the same as your CR2 file.
