Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 12:55 am)
It might be using the wrong texture. Poser has the unfortunate habit of grabbing the first texture it finds with the right name. So you may end up with the black Millennium Cat texture applied, when you wanted a black dress texture, if they are both named "black.jpg." Now most people use unique names for the texture maps, so it's not a problem, but the antelope is old enough that they might not have done that.
The way to test if this is the problem is to rename the texture you want to something unique, then apply it manually, and see if it looks right then.
I'm useing P5. The DAZ page says it uses the Daz Buck, but don't requier it. So it should work. But if it is just a modified buck mesh, then what mesh am I to use? The pack didn't come with any other file (I've worked with adding new mesh's to files before, did it when I got Lyne's wolf pack) and the Daz page says "New, stand alone figure based on the DAZ Buck" nothing else.. so.. I don't know whats goiong on..
You CAN'T apply the antelope pack textures to the DAZ Buck - manually or otherwise because they don't fit the buck. They fit the bfBuck (Big Face Buck) not the blBuck (DAZ Buck). The bfBuck geometry is installed with the antelope pack, and there are cr2s for all the antelopes installed into the figure library "DAZ Antelope" folder. Use those cr2s because they properly call the bfBuck geometry. If you want to manually assign one of the Antelope textures you MUST use the BFBuck figure.
Um........... I.... don't have the bfBuck.obj.. O.o I just did a search of my whole HD and no file matching that name came up.. ....now.. I'm totly lost.. it WAS to come with this pack right?! Cause after instaling the pack again, it still didn't give me the file.. I'm going to be mad if they don't have it in the file anymore.. I bought two packs that need this bfBuck.obj, but I don't have it anywhere on my system, and it seems to not have come with eather pack. anyway I can get the bfBuck.obj? I'll hate to have wasted cash on two packs I can't use just cause they don't come with the right object file to use them.
E-mail tech support at DAZ, or post a message in the DAZ forums. It might be better to post a message in the DAZ forums, because DAZ is way behind on their e-mail, thanks to their server crash and the Starter Bungle mass confusion. Or call. Someone at DAZ can check the file and see if there's something wrong with it. I'm sure they'll fix it, one way or the other. Give you the right file, or give you your money back, if you wish.
I got the Antelope Expansion Pak (and the Buck)
http://secure.daz3d.com/shop.php?op=itemdetails&item=305
But some reason the testure map isn't displaying right. Now the Buck's map works fine and displays as it should. But this, along with another deer set I got do this..
I tried to mess with the map cords but, it never changes. Can someone tell me how to make this display right?
