Fri, Feb 14, 2:49 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: opening file asks for texture thats not there?
7/8'sIrish ( ) posted Sun, 03 October 2004 at 5:23 PM ยท edited Fri, 14 February 2025 at 2:40 PM
Hi, I am having a creature tested by some people, when they open the file it asks for a texture that is not even in the file? It used to be but I deleted it along time ago, and saved out a new cr2. How can I stop the file being called for? thanks
Crescent ( ) posted Sun, 03 October 2004 at 5:50 PM
You need to look at the bottom part of the .cr2 in a text editor to see where it is being referenced then remove it. (At the bottom of the .cr2 are all the materials and their settings including what texture maps to use.) The incorrect reference may be in the material Preview area if you don't see any signs of the old texture map when you render the figure on your computer. Hope this helps, Cres
7/8'sIrish ( ) posted Sun, 03 October 2004 at 6:00 PM
I checked before but there is no reference to this texture map in the cr2?
7/8'sIrish ( ) posted Sun, 03 October 2004 at 6:14 PM
Ah thanks I found it. The problem was in latter versions I called the material "torso" but in earlier versions I called it "body" so I found the reference under body. I just removed the reference line- correct? not all the extra node stuff... Thanks
