Thu, Feb 13, 6:24 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 3:49 pm)
Subject: A quick way to delete material nodes in P5
Mason ( ) posted Sun, 03 October 2004 at 5:16 PM · edited Mon, 10 February 2025 at 11:29 AM
  1. With the material room open, select the object you want with the eye dropper. 2. HOLD the delete key down. 3. Click on the material nodes you wish to delete while holding the delete key down. Each node will delete immediatly as you click them.
Methastopholis ( ) posted Sun, 03 October 2004 at 5:59 PM
cool thanks 4 the intel
Ajax ( ) posted Sun, 03 October 2004 at 6:07 PM
I didn't know that one. If there are a lot of nodes it's probably quicker to right click select all and then either press the delete key or right click delete (I've noticed sometimes pressing the delete key doesn't do anything even when you have nodes selected).
odeathoflife ( ) posted Sun, 03 October 2004 at 6:52 PM
what I did was create a !white material, just your standard main material node and nothing else with ecvery thing at the default, then if I want to clear the nodes then I just have to apply the white material preset. But that is a good tip, I am constantly playaing and deleting and adding to the main material.
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
compiler ( ) posted Mon, 04 October 2004 at 11:35 AM
I usually select the nodes to delete with the standard Windows procedure : ctrl-click selects each node you want, then hit "del" key.
Terry Mitchell ( ) posted Mon, 04 October 2004 at 2:30 PM
There's also a little arrow at the upper right of the Material Room preview window that opens a dialogue box with the "Select All" option, afterwhich just hit the delete key to clear all nodes.
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
