Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 12:25 pm)
First position the prop relative to whatever you want to attach it to. Then (while the prop is still selelcted) in the Object menu choose "Change Parent". In the list that comes up, select what you want to attatch to, it might be a body part, for example. After this is done, the prop should automatically move whenever its parent does.
Before I upgraded to Poser 4.02, I was having numerous parenting problems myself, both when using the "Change Parent" function & also when doing parenting in the Hierarchy Editor. Since the upgrade, which corrected parenting bugs, no problems. I wonder if perhaps you're still using the original Poser 4.0? If you tried Doozy's suggestion & still can't get dependable result, I wonder if it might be the Version number you're using.
Whell What I did Was Inpoeted The prop as A figure And went to the figure and Change It that Way with eather the Comform to Option Or the Change Figure parent and Seem to Work out Fine I only upgraded It Once Buy the Way. it Came With The up grades I think 4.2 Is it not sure will check Version # later Thanks for The Help.. |GRID|
Hello I got a "?" I am needing the way to Attach Props and other Thing To the figures in Poser Is there a way to Do this??
