Sat, Jan 25, 5:48 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: Is that right ? can't see how many percentage is done when rendering in poser5?
digitalman ( ) posted Sun, 03 October 2004 at 10:24 AM · edited Mon, 20 January 2025 at 9:08 PM
unlike poser 4, when i do rendering in poser 5, there is no little man stand there and tell me how many percentage is done so far. this bother me when i rendering 'cause i have no idea is it really take long time to render or is my computer crash , all i can do by then is just waiting. any advice ?
svdl ( ) posted Sun, 03 October 2004 at 7:54 PM
P5 has a progress bar in a dialog window. If you do a P4 render, the progress bar will run from left to right for each light with shadows, mentioning what shadowmap it is rendering, and then run from left to right one more time during the final render - although "running" might not be the best word here ;) In Firefly, the progress bar is used once for loading the textures, twice for each light with a depth mapped shadow, and twice for the final render. If you want to know whether your render crashed, go to Task Manager, Processes tab, View-Select columns and select Virtual Memory usage and Page Faults. Monitor those settings. If the progress bar does not change during an Adding Objects stage for about five minutes, and Memory Usage, Page Faults and Virtual Memory don't change eithre, you have a crash - and from the Process tab you can kill the Poser app much faster than from the Applications tab. Few or no changes in memory usage during a "Rendering" stage is normal. But if rendering stops somewhere halfway an image, and it doesn't resume within a few minutes, you also have a render crash. Render crashes happen much more often than I like. When (not if, when) they happen, kill Poser using Task Manager, delete all .tmp files, delete all poserTemp.* files, and reboot your machine to clear out memory. AND ALWAYS SAVE BEFORE RENDERING!
My gallery   My freestuff
digitalman ( ) posted Mon, 04 October 2004 at 10:45 AM
thanks for answer my question, but I still can't see the "progress bar "on both render Firefly, and poser 4 render, shouldn't the progress bar pop out itself when I hit render now " and what you mean by "dialog window" ,do you mean "render option" window ?
digitalman ( ) posted Tue, 05 October 2004 at 4:56 AM
I set the monitor resulution to 800 x 600 .can't see the the progress bar down below, now I have to work on 1024 x 768 , not good for my eye. thanks guys
