Sun, Feb 16, 8:15 PM CST
Subject: Deleting preliminary frames (animation)
maxxxmodelz ( ) posted Tue, 05 October 2004 at 2:19 PM · edited Sat, 08 February 2025 at 11:20 PM
I'm drawing a blank on this... I have two animations I need to merge. I want to only use frames 50-100 in the second animation and put them at the end of the first one. How does Poser handle this? I understand how to delete frames from the end of an animation, but what about the beginning? In other software I've used, I had always been able to just delete a range of frames from any part of the animation I chose, but I'm when it comes to something like this in Poser.
PhilC ( ) posted Tue, 05 October 2004 at 2:25 PM
Save the required animation as an animated pose. Follow the prompts regarding frame numbers. To load it back into Poser set your scene up with the first animation. Then advance one frame and load the saved pose. Accept the prompt asking if you want to add frames.
mateo_sancarlos ( ) posted Tue, 05 October 2004 at 2:26 PM
I have a related question. The experts often say to render animations as image sequences, and I think this is a good idea. But if we're doing a 200-image-sequence animation and Poser5 crashes after rendering frame (image) 100, how do we get it to start rendering the next time at frame (image) 101? My limited experience suggests that Poser5 is always going to start rendering the image sequence at frame 1.
PhilC ( ) posted Tue, 05 October 2004 at 2:32 PM
To render a range set the "Play Range" markers at the bottom of the Animation Window. Once done you will find the info carried forward to the Time Span data of the Animation/Make Movie Window
maxxxmodelz ( ) posted Tue, 05 October 2004 at 2:35 PM
"Save the required animation as an animated pose. Follow the prompts regarding frame numbers" Thanks again, Phil! ;-)
mateo_sancarlos ( ) posted Tue, 05 October 2004 at 5:39 PM
Yes, thanks for the tip, Phil. The "play range" could also be a lazy-man's shortcut for deleting initial or intermediate frames. They'd still be there, but we wouldn't have to waste any time rendering them.
