Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Anything you save to the library will get its thumbnail from the unrendered preview in your window - in other words, things with transparency on them won't look right.
There are many workarounds :-
As sdw says, render a 91 x 91 PNG and place that manually in your library. This is for Pro Pack and Poser 5 only - Poser 4 or 3 users will need to convert to RSR using P3dO Explorer.
Set your preview mode to cartoon, then save.
Render, and apply your render to a square. Position that in front of the camera, then making sure the hair is selected, save that.
And probably others that I've forgotten. :) The PNG route is the most versatile, because you can also add text, logos etc. to your thumbnail.
Message edited on: 10/08/2004 03:07
Hi, I have a hair pose that I would love to save, but when I go to save it, it shows the head only with "dots" for the hair. I see all othere poses with hair have the hair showing....any suggestions? Thank!
Eddy
