Fri, Nov 15, 1:38 AM CST
Renderosity Forums / Writers
Welcome to the Writers Forum
Forum Moderators: wheatpenny, Wolfenshire
Writers F.A.Q (Last Updated: 2024 Nov 14 6:44 am)
Writers Gallery
"Don't tell me the moon is shining; show me the glint of light on broken glass." ---Anton Chekhov
Subject: formating problem
Gurami ( ) posted Fri, 08 October 2004 at 6:27 AM · edited Sat, 10 August 2024 at 1:03 AM
Posting a text here (or anywhere else on the net), ruins my manuscript format. Tabs dont work; multiple spaces are omitted. Is there a way to start every new paragraph with an indentation? Maybe an HTML tag? I hate writing huge blocky paragraphs, especially when it comes to dialogue. However, short paragraphs are problematic: Due to the lack of indentations, you cant tell a linebreak from a new paragraph, unless you insert a blank line after each paragraph. But then the text has more holes than a swiss cheese. Do I have to put up with this or is there a solution?
experimental ( ) posted Thu, 14 October 2004 at 3:38 PM
& nbsp will add extra spaces (remove the space from after the &) I have a tendency to double enter between paragraphs because not everywhere accepts HTML formatting in posts.
          just testing
Gurami ( ) posted Fri, 15 October 2004 at 2:18 AM
      Thank you, experimental. Thats exactly what I need.
GonWaki ( ) posted Sat, 16 October 2004 at 12:09 AM
Although " " works well enough, it can make your text difficult to edit afterward. To make text look cleaner, you can instead use the
 and
tags. "Pre" stands for preformatted. Give it a try! In the beginning there was absolutely nothing. No voters, politicians, or pollsters. Life was good when there was nothing. Only after some ungrateful caveman started playing out in a thunderstorm did we get fire. From there it was all downhill.
     Ok, it goes way beyond stupid, but you
get the point.  The beauty of this method is
that you don't need to use that annoying
  everwhere.
