Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
Hi Shadow You add Imagemaps to the Diffuse color (the very top node in Poser 5), though be careful to make the Diffuse color light enough to see the map. I usually use white. Hope that helps John
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
I recently Bought Sharky's Angelina wings and was very excited to start using them. I was a little perplexed though that the default color of the wings seams to be pink. That is unless I want to use the black option. Being short on cash I went to the freebie section here at Renderocity and found two mats for the wings. Again, I was Excited but I am having trouble again. The mats are in image maps and bumps and the like. I understand to load the bump image into the bump node but I can't seem to figure out where to attach the image map. I tried on the ambient color (which is pink) and it does load the map but the color stays pink. How do I load this thing to get the desired mat for the wings? I went to the poser 5 manual but that made me more confused than before. Can someone who has used these things help me out?
