Tue, Jan 28, 2:16 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 11:56 pm)
Subject: how to apply image file in materials room
shadowrelm ( ) posted Tue, 19 October 2004 at 12:00 AM ยท edited Mon, 27 January 2025 at 2:03 AM
I recently Bought Sharky's Angelina wings and was very excited to start using them. I was a little perplexed though that the default color of the wings seams to be pink. That is unless I want to use the black option. Being short on cash I went to the freebie section here at Renderocity and found two mats for the wings. Again, I was Excited but I am having trouble again. The mats are in image maps and bumps and the like. I understand to load the bump image into the bump node but I can't seem to figure out where to attach the image map. I tried on the ambient color (which is pink) and it does load the map but the color stays pink. How do I load this thing to get the desired mat for the wings? I went to the poser 5 manual but that made me more confused than before. Can someone who has used these things help me out?
xantor ( ) posted Tue, 19 October 2004 at 12:58 AM
Attach the image to the diffuse color. The ambient colour is for glowing effects so you might want to make that black with no map attached.
Fugazi1968 ( ) posted Tue, 19 October 2004 at 1:02 AM
Hi Shadow You add Imagemaps to the Diffuse color (the very top node in Poser 5), though be careful to make the Diffuse color light enough to see the map. I usually use white. Hope that helps John
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
geep ( ) posted Tue, 19 October 2004 at 10:53 AM
cheers,
dr geep ... :o]
edited 10/5/2019
shadowrelm ( ) posted Tue, 19 October 2004 at 6:05 PM
Thanks for all the help Guys. I have really learned a lot. I am including some PICS of my renders to let you see what happened. In the first image I applied the image map as well as the trans map the diffuse color. (By the way I loaded the Black Angelina Wings option for the exercise.) I was able to see the map but everything was still mostly black. I went down the line and changed all the default colors to white and rendered. I got the first image. Nice but still a little dark. I couldn't figure out what was happening at first but then I had an epiphany. The Angelina Wings are composed of 6 different feather groups as well as feather shafts. I had changed the image map and trans map of feather group 1 but none of the others. They were all still the default black. So after going though all the feather groups and shafts I ended up with my second render. More what the mat is supposed to look like I am sure. And I removed V3, she was distracting. :) Again thanks for all the help. You people are great.
