Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
There is no Copy function in Poser (whatsoever). You will need to keep adding the same figure/prop to the scene. Ain't Poser grand?
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
cheers,
dr geep ... :o]
edited 10/5/2019
In an empty Poser document, hide the GROUND and set the background colour to black. Load your tree, do a render, export an image in TIF format, name it "MyTree".
These are instructions for Poser 4, and PaintShop Pro 5, but you should be able to do a simmilar thing in most paint programs.
Load the MyTree.tif in PSP5, load the mask from the alpha channel. Invert the mask. Save this image as MyTree_TRAN.tif". You might want to convert the final images to JPEG format and use some compression to get smaller files.
Open Poser Load a Poser square prop. Set the Highlight Color to black, set the Highlight Size to 1%, set Transparency Min and Max to 100%.
Load MyTree.tif as the texture and MyTree_TRAN.tif as the Transparency Map, click OK. Resize the square as appropriate, and save it to a props pallet. You now have one light weight "Billboard" tree, you can load many of these without using a lot or resourses.
Of course you won't be able to see it properly untill you render.
Attached Link: http://www.dddwelten.de
Hi all,what is the way to duplicate a object in Poser 5. I create a little tree and paste him in my work on place x,y,z.OK.
Then i will duplicate the tree to construct a little wood.
My scene is a large scene and the the way to put the same tree out of the library an place it near the first tree is
large in time.
Following i testet. : Mark the tree press the copy Button and then i will paste it with the function paste strg-v.
It dont works.
Please give me a little tip
Regards micpic
