Sun, Jan 12, 12:10 PM CST
Subject: Motion Blur
LordWexford ( ) posted Thu, 21 October 2004 at 10:30 AM · edited Sun, 12 January 2025 at 12:09 PM
Simple question that I really should know the answer to :-) How do I add motion blur to an object in Vue 5? I can't seem to find the answer in the manual ... ... Thanks, Bernie
nanotyrannus ( ) posted Thu, 21 October 2004 at 10:57 AM
I just read part of a tutorial somewhere in the manual, I don't recall off the top of my head but it should be under the animation section somewhere (you have to animate the object in order to achieve motion blur).
wabe ( ) posted Thu, 21 October 2004 at 11:16 AM
Well, page 59 in the manual... You have to do an animation for the object you want to blur. And then render a frame of this animation (or the whole sequence of course). Keep in mind that the start or the end frame of an animation do not have any blurring because there the speed is zero. So you have to render a frame somewhere in between. The rest are more or less render settings. You need to render in broadcast or higher. Only then blur is available. More or less because the amount of blurring depends on the speed of the object, in relation to the camera. So it sometimes needs a little tweeking there too. AND, effects like that (motion blur, dof etc) will increase the render times a lot. So don't be surprised...
LordWexford ( ) posted Thu, 21 October 2004 at 12:23 PM
Thanks for that. I hadn't realised that I needed to do an animation in order to create motion blur. I thought that I could just select an object, and say "apply motion blur to this". I should have known that life is never that straight forward!! :-) Bernie
wabe ( ) posted Thu, 21 October 2004 at 3:06 PM
When you do stills then it might be an option to do that in postwork. Photoshop for example. Good control and exactly as you want it. Select an area and say "motion blur please". The "please" is important of course - otherwise you have to do it manually! To make it easier you can render objects separately with mask and combine those in Photoshop. Only another option.
bonnyclump ( ) posted Thu, 21 October 2004 at 4:26 PM
Hi, here's one I did in vuepro by animating in poser to make the still in vue so as to capture the motion blur. I think its worth trying to squeeze motion blur out of vue instead of faking it in photoshop, afterall did you buy vue to use photoshop, but to each his own. It is possible in vuepro and the results are cool. It takes time to figure out how fast the motion needs to be in poser to look good in vue but I think its worth it. Good luck
jwhitham ( ) posted Thu, 21 October 2004 at 6:41 PM
bonnyclump, that is a great image. The DOF and motion blur are amazing, as is the tension line created by the dragons' wings and necks.
My 2 Euros worth, not that you asked for it, but the tip of the spear needs to be, even more than it already is, the central point both geometrically and in terms of lighting. Get it to really catch and reflect some light!
John
bonnyclump ( ) posted Sat, 23 October 2004 at 1:19 PM · edited Sat, 23 October 2004 at 1:27 PM
good idea about the spear tip. Thanks for the tip : ) and the compliment.
Message edited on: 10/23/2004 13:27
JeffAlberts ( ) posted Thu, 04 November 2004 at 9:03 AM
I've been trying motion blur in Vue4. And the results are less than I was hoping for. The edges of the blurred item, and it's shadow, are very grainy, nothing like the image above. I'm doing a very high-res render with the best settings possible. My guess is that Vue5 or VuePro does this better. But I would be interested to see any motion blur samples done in Vue 4 (not pro) to see if they are drastically different from mine. Thanks, Jeff
