Tue, Jan 14, 6:26 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 4:58 am)
Subject: Getting rid of little red handles!
cjw ( ) posted Sat, 23 October 2004 at 11:40 AM · edited Tue, 14 January 2025 at 6:24 AM
My newbie question: Some clothes have little red handles that are shaped like cones to help you adjust the fit. That's all well and good, but how do you get them not to appear in the render? There has to be some easy way to hide them or turn them off, but I can't find it. Thanks for your help.
SndCastie ( ) posted Sat, 23 October 2004 at 11:47 AM
you can make them invisable just slide the dial on transparency :O)
Sandy
An imagination can create wonderful things
SndCastie's Little Haven
lesbentley ( ) posted Sat, 23 October 2004 at 11:51 AM
Normaly these handles wont appear in the rendered image as their materials are usually set to be transparent. If they do still show in the rendered image you can select them with the cursor, then from the menu bar "Object" menu, select "Properties" and un-tick the "Visible" box.
nomuse ( ) posted Sat, 23 October 2004 at 7:06 PM
Many modern items using body handles have a set of poses to show or hide them as well. Standard seems to be red cones although I've seen green balls -- anyhow, look for one of these with the International "NO..." around it (in the pose file).
byAnton ( ) posted Sun, 24 October 2004 at 12:17 PM
Hi there, Most Daz items that use bodyhandles have P4 MAT files to hide and unhide them. I made alot of them, but can't speak for newer items. If the material name for the bodyhandles is still being used consitantly, you can copy the on/off Mats into other folders and use them on newer items too as long as the material name matches. Regards, Anton
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
cjw ( ) posted Sun, 24 October 2004 at 11:16 PM
Thanks to one and all for the suggestions on how to disspell those little, red dickens! Apparently, there is more than one solution depending on the original creator of the object. At least now I have some new things to try. Thanks again.
SndCastie ( ) posted Sun, 24 October 2004 at 11:38 PM
Your welcome always willing to help if I can :O)
Sandy
