Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
My python page
My ShareCG freebies
Thanks for the clarification. If the groups must be made in Poser (by individual selection in the grouping tool) then the Setup room just isn't worth the trouble for my purposes. The grouping tool is too fussy; too easy to make unrecoverable misclicks. So I'll stick with the old method of importing the parts as separate objects, building the hierarchy in Poser, and creating the fig from the hier, without ever touching the Setup room. This method works reliably, and lets me do most of the "microscopic" stuff in Amapi, where it's easier to handle. I was just sort of hoping that the Setup room could make things faster instead of slower! ... sigh ....
My python page
My ShareCG freebies
Hi ockham,
Did you check the "List of Groups"?
If the "List" contains the correct groups, i.e, the ones you want, then all you need to do in the Setup Room is:
(using the Grouping Tool)
When you are done, you can delete all groups that are not required.
Poser will automatically delete the NO_BONE group if it is empty, i.e., all polygons in the figure have been grouped to a bone.
Would this work? ;=?
Just a thought. ;=]
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
My python page
My ShareCG freebies
OOPS !!! ;=[ Sorry Antonia ..... you're right ..... Doc's wrong. ;=[ (sniff) re:"Poser will automatically delete the NO_BONE group if it is empty, i.e., all polygons in the figure have been grouped to a bone." <----- WRONG! The NO_BONE group will not appear in the Pose Room but it may still exist in the Setup Room and must be deleted manually (if desired). If the NO_BONE group has been deleted and a subsequent operation causes a polygon(s) to not belong to a "bone" (group), Poser will recreate the NO_BONE group auto-magically. ;=] The NO_BONE group exists to "catch" any polygons that may have been removed from a previously "boned" group. cheers, (anyway) dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
My python page
My ShareCG freebies
Hi Folks, You can find Page 21 if you CLICK HERE. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
