Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 05 12:55 pm)
This is art - this is not pornography - parts of the human anatomy are valid in Art - Renderosity only sells products for Artistic Purposes. I am an artist, please make no other judgement about me. This is the most difficult to build product my team has ever produced, so don't say its an easy buck either. Thank you and enjoy, Marty
Firebirdz: No,the Daz M3 Genital maps cannot be used on it, but the maps that come with it were made to match the skin of the m3 maps from Daz,there is also a map to match the v3 map from Daz.there are also a set of brightness and tones mat poses to change the color of the G4,like those that come with the Daz generation 3 textures. The3dZone
Funny YouTube video of the week - Bu De Bu Ai
The3dZone
Morris, I think you're going to love it. I know I loved working on it! Papa, it doesn't pre-conform to any figure, but with the morphs I created and some scaling/repositioning, you can parent it to any figure. I've used it on David several times, and on The Freak once or twice. It conforms /beautifully/ to M3, though.
Kreations By Khrys
Introducing G4forMen Ultimate by Insomniaworks, The3dZone, and Khrys
This is the most difficult that I and may partners have ever developed. It took four months to perfect and involved much testing and experimentation with three prototypes prior to developing the final geometry.
This Penis was set up to work specifically on Michael 3.0, but has plenty of options for making it work across a spectrum of characters. It can be smart propped as well as conformed and has special morphs installed for fine fitting to other characters. It comes with both Tone adjustments to match DAZ's standard tones as well as Brightness Adjustments.
This penis is different in one way from all other penises because this one was modeled in an erect position. I have always wondered why penises were modeled in a flaccid state because the they tend to not look well when made erect. This was done opposite, so it looks it's best when erect. TOS does not allow me to show this product in the erect state.
The Penis contains twelve groups in this order: Scrotum, Hip, Nine Shaft Sections, and Glans. The nine shaft sections seemed just enough to do realistic poses with out sharp edges, while not being too many being overkill.
This product is Jam-Packed with Morphs all operated from the Body group. There are Thirteen morphs in the Scrotum, Four along the Shaft, Eight in the Glans and Four morph in the Hip for adjusting Fit.
**Here are some excerpts from the readme.txt. **
1)G4forMen, Penis for Michael 3.0 by Daz3D.
Copyright 2003 - Insomniaworks (insomniawork@yahoo.com) Geometry and Set up for Poser,
The3dZone (sroth@the3dzone.com) Textures
Khrys-Morphs (silverbishounen@yahoo.com) Morphs
Thank you for buying our G4forMen, Penis for Michael 3.0.!!!
You MUST own Michael 3.0 Base Package available from DAZ3d.com. You must own M3 Body Morph Pak from Daz3D to use all aspects of this package.
Penis - a posable conforming penis figure for M3
Foreskin - a conforming forskin figure
Load Michael 3.0
Go to the G4forMen Figure library and select the Penis first and then conform it to M3. Newbies: Load by highlighting the Penis Thumb in the Figure library, then click the Double Check near the bottom of the library window. This will add a figure to the scene.
Optional Foreskin: Load the Foreskin from the figure library and conform it to the Penis.
This product makes use of ERC code in both the Penis and Foreskin. What ERC does is make morphs adjust remotely from same named parameter dials in other figures. There is a delay-that is you must move camera angle slightly (or hit Control-Z twice) for slave morphs in other figures to catch up. I insist that you load these 3 figures first before other figures in your scene in the order mentioned (M3-Penis-Foreskin) This will help to avoid cross-talk errors.
The Penis and the Foreskin have two morphs to match M3 full body morphs - only two were needed, _Skinny and _Emaciated. If you have either of these full-body morphs installed on your M3 character, you can dial these penis parameter dials to match M3.
The PENIS BODY GROUP contains all the morph control over both penis and foreskin ,minus one (BR_ForeBack to be explained later).
Morphs for use with foreskin
1)BulbusRemove - this is recommended to be used at all times while using the foreskin figure. This will make the lines of the profile of the penis more natural with the foreskin.
Shaft or Midsection Morphs
2)Girth - This will make penis shaft and glans stouter on an X axis
3)Thick - This will make penis shaft and glans stouter on an Z axis
4)MidShaftYScale - This will make the interior of the penis shaft grow fat on an Y axis while scrotum and glans remain the same size.
5)MidShaftXScale - This will make the interior of the penis shaft grow fat on an X axis while scrotum and glans remain the same size.
Glans Morphs
6)GlansStyle - Rotates the glans upward or download changing the appearance of the glans.
7)GlansSkinny - Narrows glans on an X axis
8)GlansMidCurve - This expands the middle of the glans changing the curve of the glans.
9)GlansTipYScale - This expands the tip of the glans on the Y axis changing the curve of the glans.
10)GlansTipXScale - This expands the tip of the glans on the X axis.
11)GlansMidXScale - This expands the middle of the glans on the X axis changing the curve of the glans.
12)RidgeY - This expands the farthest back part of the glans or the ridge on a Y axis.
13)RidgeNarrow - This expands the farthest back part of the glans or the ridge on a X axis.
Testis or Scrotum Morphs
14)TestesRealistic - Changes shape of Testes
15)Swing Forward Testes - Self explanatory
16)Swing Back Testes - Self explanatory
17)Swing R Testes - Self explanatory
18)Swing L Testes - Self explanatory
19)Up R Testis - Self explanatory
20)Up L Testis - Self explanatory
21)Up Both Testis - Self explanatory
More Scrotum Morphs - I recommend dialing all these five morphs to 1 at the same time for full effect.
22)ScrotumDefineFore - Makes indention in the fore region of the scrotum making it look more realistic
23)ScrotumDefineR - Makes indention in the right side of the scrotum while shaping the testis
24)ScrotumDefineL - Makes indention in the Left side of the scrotum while shaping the testis
25)ScrotumXSizeR - Moves right testis closer toward center
26)ScrotumXSizeL - Moves left testis closer toward center
Abdomen Morphs - While having full control over orientation with x,y,z dials, these morphs have been added for fine adjustments to the abdomen portion of the penis.
27)BaseXAdjust - Shrinks or expands abdomen portion of penis figure on the X axis
28)BaseZAdjust - Shrinks or expands abdomen portion of penis figure on the Z axis
M3 Full-Body matching morphs in the Penis Body Group.
29)_Skinny - This morph is to be operated manually. Set this to match the Skinny morph in the M3 Body.
30)_Emaciated - This morph is to be operated manually. Set this to match the emaciated morph in the M3 Body.
EZPose Parameter Dials in the Penis Body Group.
31)TwistAll
32)SideSideAll
33)BendAll
34)Sside
35)SBend
36)SpiralSide
37)SpiralBend
38)Wave1S
39)Wave2S
40)Wave1B
41)Wave2B
Foreskin Morphs - The FORESKIN BODY GROUP contains only one morph that you can operate from the Foreskin Body Group.
31)BR_ForeBack - This rolls back the foreskin back from the glans. It is designed to work a little past 1 on the parameter dial. This is to be used only while using BulbusRemove morph located in the Penis Group. Only with this morph will the penis be the proper shape for the foreskin and this morph to work.
Hip orientation Dials - The XRotate, XTrans, YTrans, and ZTrans dials in the hip group of the penis has been hidden. They have been replaced by dials that are named xRotate_Fine, xTran_Fine, yTran_Fine, and zTran_Fine to adjust the sensitivity of those dials. This will give you 100 times more control to make fine fit adjustments.
PENIS POSITION FINE CONTROL FURTHER EXPLAINED
()These are variable to .01 of the normal variation. You will now have 98 possible positions between .000 and .001 for instance. You must place your pointer over the dial and roll the dial to get fine adjustment. If you just type in .001 you will defeat the purpose. The dial will still say .000 or .001, but you have a lot of variation in between when you roll the dial. You can use these parameter dials to make fine adjustments for fitting to M3 (if you feel they are needed) or for fitting to alternative characters.
!Brightness 1 through 6 - For custom usage - this will change the brightness of the penis or foreskin
!Tone 1 through 7 - These match the Tone Settings from the M3 and V3 Texture packages.
1)Base1 - Texture : matches the m3 map high-res that you get from daz
2)Base1_Alt - Texture : has pubic hair - matches the m3 map high-res that you get from daz
3)Base2 - Texture : matches the V3 map high-res that you can get from daz.
4)Base2_Alt - Texture - has pubic hair - matches the V3 map high-res that you can get from daz.
base 1 and 2 are for the user to create their own maps,thats why they are without the hair painted
_alt textures contain pubic hair.
double click the thumnail to apply the texture.
5)Blank : Blank texture
Poses can be achieved by adjusting each body part of the penis and then saving poses to the library. Here are a few to get you started.
1)Pose_Default
2)Pose_Erection
3)Pose_Flacid
"!Brightness0","!Tone0","Pose0" and "Base0" are lables only. They are not functional.
The BR_ForeBack Morph in the penis body group is made to be used with BulbusRemove morph in the penis body group. This was explained earlier. BR_ForeBack morph alone may have some poke-thrus when used in conjunction with other morphs such as Thick or MidShaftYScale. Rather than making a set of BR_ForeBack morphs to compensate every morph combination, and use up memory, we have included these two magnets. These magnets will correct minor poke-thrus. These magnets will not show up during renders and can be made invisible during normal viewing.
1)BR_ForeBack_BotAdj - Select the ForeSkin Figure then load the magnet. This magnet is set up with the magnet zone in just the right place to correct bottom poke-thrus and the magnet already has some yTrans applied. You may need to adjust the x,y,and z Trans Dials for your perfect the adjustment.
2)BR_ForeBack_TopAdj - The explanation is exactly the same as above except this magnet is for top poke-thrus.
on offence insominiaworks, but it looks more like a mushroom than a penis. Maybe its the angle but the head just doesnt look right.
My Homepage - Free stuff and Galleries
ok, i started typing before you posted that part and didnt see the morph stuffs.
question. XXXXXXXXXXXXX never mind, you answered it while i was typing :)
Message edited on: 11/04/2004 12:31
Nice promos, 3dZone! This is just one of those products that has taken a long time to complete, and a long time to test, because we wanted to be sure everything worked perfectly, and I think that the testers, who worked very hard with this set, caught every bug. Personally, I've used several different penis props, over the years, and this one is the most versitile. Unlike the Daz3d penis that comes with M3 and David (But poor Freaky got left out!!!), this one has a lot of morphs and a lot of sections to make it be able to do every kind of penis I've ever seen. Hey, Insomnia, when can we expect it to hit stores?
Kreations By Khrys
FYI: The G44M has just hit the marketplace!!! The3dZone
Looks good overall. doesnt conform to David well. tears the scrotum :-0 if you tell it to conform but works fine if you use the hierarchy table to attach it to the hip and manually adjust the location by moving the hip. (btw one of the dials in the hip is mislabeled, you have 2 labeled as y trans.) Length can be adjusted to some extent by choosing a few of the mid sections of the shaft and scaling the Z. as with all other models I have seen the scrotum doesn't shrink well beyond a certain point (i.e. you cant truly represent someone who is cold/underwater), and the difference between erect and flaccid is only represented by a change in the direction its pointing (not a change in length, girth and thickness that naturally occurs.)
I think it is fabulous, the best I have ever seen by a mile! I have waited so long for this male genital (good grief, one needs to be so careful of double entendres) and it was well worth it imho. A 'length' morph might be a great addition though ;)
"I am extraordinarily patient, provided I get my own way in the end" - Margaret Thatcher 1989
Thank you kristinf and Tyger_purr! Yes, smartpropping is the way to fit on another character if anything strange happens. To do that, one can find the penis in the hierarchy editor and select it and drag it over the hip of the figure in the hierarchy list. I hadn't even thought of cold-water scrotum shrinking morphs, nor did anyone ever request it and I had about 20 people testing and making sugestions. Marty
In a few days the G4forMen Ultimate will be coming out in the market place. Since this is a penis and the images may offend a few, I am going to exercise a little desecration and post images to this thread rather than the regular promo area, and re-direct from there. Please make sure that you understand that the advertised product is a penis and please do not scroll down unless you want to see images of the product. All images will fall within the Renderosity TOS ------------------------------------------------------------ Members/Users will not use this community for; Any practices that affect the normal operations of the community (Admins will take whatever steps are necessary to restore service). Transmitting any libelous, defamatory, or any other material that could give rise to any civil or criminal liability under the law. Personal attacks. This includes but is not limited to, destructive, abusive, defamatory communications in any form, and retaliatory attacks from personal attacks. If you need assistance, please communicate with someone from our Renderosity Team. Destructive commentary/communications made with the intent to disrupt or attack (Trolling). This applies to any communications within this community, whether in the forums, art galleries, graffiti wall, chat, or IM. Advertising or linking to any publications and/or web sites that are age restricted due to content, and/or pornographic in nature. Posting Unacceptable Images or Writing Themes: No Rape [actual or implied] No Torture [defined as: the infliction of intense pain (as from burning, crushing, wounding, crucifixion) to punish, coerce, or afford sadistic pleasure] No Sexual acts [no depictions of sexual intercourse - between humanoids/non-humanoids/animals - no masturbation] No Physical arousal [This includes but is not exclusive to: no images of an erect penis/ no images showing the inner portion of the vulva or vaginal area] No Explicit sexual content [No manipulation of breasts/nipples/ no sexual situations/ no implied sexual acts/ no extreme or explicit S&M bondage situations/ no lewd or obscene sexual references] No Genital contact with ANY object, other than sitting or clothing. No depictions of young humanoid characters/children giving the appearance of being under the age of 18 where genitals are displayed and/or in erotic, seductive, provocative poses or context. Since age is difficult to identify with 3D images, this will be at the discretion of the Renderosity team. No character attacks, which could be interpreted as defamation of character, slander, and libelous. A signed model release with Photo-ID must be provided upon request if posting images with photographic nudes. Additionally, any post, image or writings can be removed at the discretion of staff if it is deemed unsuitable for this community. Conversely there may be some images which, whilst in apparent violation of the rules, will be permitted to stay in the interests of free speech and religious tolerance. In such cases the artist may be asked to furnish reasons why the image should be permitted to stay and the decision of the Renderosity staff will be final. --------------------------------------------
