Well it'll slow cause it has to process info in the cr2 and it has to render the segments. what it shouldn't do is load the obj 4 times for 4 segments for example. It still has to render the 4 segments so that slows things down. Since they are characters you can hide them easily till you're ready for your final render then unhide them all. A prop tends to store vertex and mesh info in the cr2 so even though 4 props are exactly the same they can be duplicated 4 times.
Attached Link: Mr. X Poser Site
Real easy to use. Just plop down each block on even increments then hide and unhide walls for what you need. Build hallways, open areas, offices, whatever very fast. Its a character so it uses the same obj mesh regardless of how many segemnts you load (unlike a prop that duplicates the mesh data). Custom dials allow you to open and close doors or elevatro doors. Plenty of materials for everything from seperate up/down elevatro lights to top and bottom door panels. Sorry, windows don't open but the glass can be made transparent. Comes with some sample, rug, ceiling, wall and reflective maps. I put a 5x repeat rate on the floor, wall and doors so small bitmaps can be used and repeated with good granularity. Its on Stas.net so it maybe slow to access.
