Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
There's a secret hair-generating trick in Poser which creates a fractal nightmare atop Posette's head. Since it doesn't create a useful hair prop it isn't used much. I forget the keystrokes that invoke it. People who want to play with the alternate UI should be aware of the mysterious X category in each library list.
Ok, I tried using the alternate UI (PC), but after the alternate boot screen, the program just hangs. (empty screen, hour glass showing it's busy - but never goes away) When I turn the meta UI back on, everything is fine again. Anyone got an idea what the problem might be? BTW: Looking at the ini file, there are a couple of other cool changes you can make, such as increasing the size of the Hierarchy window. -SMT
Attached Link: http://poser.al.ru/work/poserhack1.jpg
Without the comments. Poser 4.0.3.126. In the PoserRuntimeprefsPoser.ini file set USE_META_UI to 0. By making these changes you not only change the UI. POSER required MUCH less to memory and system resources.
