Mon, Jan 27, 1:05 AM CST
Subject: Muzzle Flash Light
speedgoat ( ) posted Mon, 08 November 2004 at 8:36 AM ยท edited Sun, 26 January 2025 at 11:30 PM
Any idea how to create a muzzle flash light in an Poser 5 animation? Not the fire itself (it seems to be best to do it in a compositing tool)but a light wich lightens up the face and scene everytime the trigger is pulled. Thanks
zorares ( ) posted Mon, 08 November 2004 at 8:55 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=302796&Start=37&Artist=zorares&ByArtist=Yes
Well, I've never done a muzzle flash in an animation but I have simply used a real flash in post. It could be possible to add the flash in post production frame by frame. Bit of a pain but it should work.
http://schuetzenpowder.com/sigs.jpg
dbowers22 ( ) posted Mon, 08 November 2004 at 8:57 AM
Couldn't you just parent a spotlight at the end of the gun? Then where ever the gun points, so does the spotlight. Then you could set the colors and even include a shadow You would probably have to manually set the intensity for each frame of the animation though.
pakled ( ) posted Mon, 08 November 2004 at 10:54 AM
Anthony Appleyard had a muzzle flash prop..don't know how much good that is, but if you search his free stuff here, you should be able to see it it's up yer alley..;)
Connatic ( ) posted Mon, 08 November 2004 at 7:28 PM
I have had success with lasers and plasma-swords using a cylinder with transparency edges and ambient color and translucent color.
mateo_sancarlos ( ) posted Mon, 08 November 2004 at 9:46 PM
If the frame rate is 30 fps or less, then you only need one frame with muzzle flash. Do the entire animation without flash, then replace the single critical frame with one that is positionally identical, but now with a cluster of 6 spotlights and Tony's flash prop or whatever.
