Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
I believe you can also adjust the production frame size by going into the render room and specifying the intended resolution for the final image. A couple of days I go I rendered some "widescreen" video -- when I changed the image output size from the default setting (640x480) to 350x100, this change was reflected in the PF in the assemble room. This method is probably not as reliable as Chuck's suggestion, but it may be worth trying out. Todd
I am working on an 800 x 600 job but want the safe area to be 640 x 480. How do I change the Title Safe Margin to 640 x 480. The documentation (page 142) says to go to File Menu>Preferences:3D View and Adjust the Title Safe Margin. I have been there. It doesn't give me that choice on my version. (3.0.4). All that is there is rotation constraint and update current pane only. Help!
