Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Why can't I color the GROUND. I select it as the prop, when I move the camera I see the border of the GROUND, but if I go to properties, "Make Visible" is dim. I use the paint bucket, but the command goes thru the floor and colors the background or foreground. I go to MATERIALS and put the "default ground texture in place, and take it away, makes no difference. There is a tiny color button to the right of the documnet display, the bottom one of four, which "seems" to be for setting ground color, but now clicking, dragging, etc. seems to work. Can't search in the old Poser manual, no search function. Search here at Rendow found no answer. I feel like a real idiot! Poser4 ProPak, everything working fine, on WinXP ::::: Opera :::::
