Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 29 7:06 am)
first i would recommend changing your document display style to texture. and see if that helps. did you install all the updates for poser4? sorry i can't be of more help maybe others will have an idea. netta
Thanks for the ideas, netta...but as I said somewhere in that lengthy moan '-)...I have tried all document settings and I believe that 4.03 is the last/most current update? Hopefully you're right that others might chime in on this 'cuz I feel like I've lost a body part myself trying to do renders without Posers '-)!
I've had this problem before. I couldn't get it corrected, either. Somehow I'd completely trashed my registry and for some reason the Poser related bits would not restore. It happened around the time when I was ready to buy P5 so I gave up on it eventually. P5 installed without a problem. Sorry if this is bad news for you. I'm certain there must be a solution but I have no idea what it is.
What about a reinstall of Poser 4? You might even try removing the software from your hard disk. Back up your Runtime folders -- the uninstall shouldn't take off any files NOT in the install list anyway, but it wouldn't hurt to backup anything you're afraid to loose. Then do a fresh install of Poser 4. Good Luck, Rance
Thanks, Rance...but I have uninstalled from the Control Panel as well as through the Poser uninstall option. And trust me '-) I'm a veteran of having Runtimes all over the place...LOL...so that part of it wouldn't be an issue! BTW...I am now up to reinstall #6...gonna wear the installation disc out 'fore this thing gets remedied I'm afraid '-)! ==steve==
Steve, it sounds like you're deleting libraries and things you don't need. I wonder if that is part of the problem. Also, if you have Poser 4, all your stuff should only be in the main Poser Runtime. So maybe I misinterpreted your statement about Runtimes all over the place? You might consider running CorrectReference (free) to see if that will help your problem. There is a chance your Poser installation is so mixed up that only CorrectReference Pro (CRPro) can help fix the problem. If so, you can find it here in the Marketplace.
Had something similar once .. happened immediately after I played with the virtual memory settings in XP. There is a memory issue with puters above a certain memory level (early morning here, caffeine hasn't kicked in yet, brain not functioning) with a patch file available at CL. It's also possible the prog you installed and removed had a tinker with your virtual memory, but didn't put it back how it was. There are threads around here on this issue .. do a search and good luck. btw 4.03 is the latest P4 issue. But your new powerful machine prolly needs that memory patch.
A possible help.. Back up your entire MetaCreations folder in a Zip, Rar, or whatever it is you use immediately after installing Poser 4 & the .03 update. Delete 1 of the folders you're removing and test Poser.. if it works, delete the backup, and make a new one (now lacking that folder) Repeat until you find what you're deleting that causes the problem.
or, if you really want to torture yourself, un install, run regedit, use the find feature in the edit menu and search for metacreations through the entire registry, then delete anything that shows up. no metacreations, find for curious labs. still no joy, find poser. also, search for and delete anything left from the realactual player. then exit regedit after deleting every registry key. then re-install poser. if still no joy. wipe the drive and rebuild everything.
The invisible character phenomenon is usually linked to having too much memory. If you're certain you have all the applicable updates from Curious Labs, including the memory updater, check your virtual memory size. If it's really big ( >2GB ) try reducing it below that figure. Let us know what Windows version you're running if you need more detail on that.
Thanks to all for your ideas/suggestions/thoughts as I am sure that I WILL eventually use each and every one of 'em AND thank goodness, being the computer illiterate that I am, that English Bob's thoughts turned out to be correct! I did indeed have my minimum set to over 3GB and upon lowering it to just under 2Gig all is (for now anyhoo) well'-)!! And thanks to moochie as well for reminding me to get that memory updater...knew there was something that was missing from the new toy '-)! And @ Bobbie Boucher...I do have multiple Runtimes, it's just that my Runtime is so large...bet we all have that lament, eh '-)?...that I install and remove various libraries as needed depending on the render I am currently working on.
Thanks to all and I'm sure that somewhere down the road my fleeting memory will require me to use each and every one of these suggestions '-)!! ==steve==
Hmm, I had a much worse prob. Namley updated to see if cold get the Cat-girl for Aiko to work for me (well it did but when went to render got that one annoying error, caught c) and so got it loaded went to open and then got asked if wanted to let it access the net, well said yes and then went into an error fest X_x that drove me nuts, so had to uninstall and reinstall the copy I have. I'll be buying poser Artist down the road to kind of help fix this I hope.
