Fri, Nov 22, 6:44 AM CST
Subject: edges
momodot ( ) posted Sun, 05 December 2004 at 2:29 PM ยท edited Mon, 22 July 2024 at 11:19 PM
I made something in Anim8tor and when iI open it in poser the edges are smooth and the planes are weirdly iluminated... is ther anything I can do to fix this now after the fact? I tried UVmapper but that didn't work. Thanks.
randym77 ( ) posted Sun, 05 December 2004 at 8:49 PM
Can you post an image of the problem? Which boxes did you check when importing into Poser and exporting from UVMapper?
wyrwulf ( ) posted Sun, 05 December 2004 at 9:13 PM
Are you using Poser 5? There is a smoothing setting somewhere in there. With UVMapper, you would use the "split vertices" tool.
Maz ( ) posted Tue, 07 December 2004 at 4:34 PM
Without a picture it's hard to diagnose your problem, but try this http://www.renderosity.com/messages.ez?Form.ShowMessage=195387 regards, Maz
