That looks amazing. Thanks for sharing.
Very interesting approach! Calculating the light vector outside of poser is just the breakthrough idea that eluded us (or at least me) so far. I would be very interested about the reasoning behind the fresnel effect spots at 45. All fresnel effects I have read about work different (mostly on the specular channel), but your effect sure looks good. Was it just try and error or is there some interesting piece of theory behind it?
Quinlor, glad you got something out of the tut. Fresnel Effect....well at one point I had this theory that light reflected a different colour based on the angle it hit the skin (almost like the skin cells bounced back white light straight out, and red light if it hit the side of the cell. If you had a look at any photo taken with a flash, you'll see all the 45 degree skin surfaces are red, and the facing skin is white. So it all sort of made sense and I implemented the fresnel effect. Then I got more into sss and realised that's what was causing the redness, so I removed the fresnel effect, implemented the incident effect, but the renders still lacked a little something. So I added the fresnel again! The fresnel is almost impossible to see, but you notice it if it's not there.
Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
I'm having a bit of a problem though, I'm illuminating my scene with a couple of 180 (limits edited) intense (200%) spotlights inside a reflecting cube. I have recreated the Real Skin Shader manually following the tutorial, but I'm getting strange black spots around what I assume are polys almost parallel to the incident light. (See examples above and below - Nudity checked but probably not required)
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
I have attached my body skin material file in case it will help solve my problem. The file is probably only useful to other Mac users who can't run face_off's Python Shader Setup script, but it would have to be modified manually to change the texture, bump and the normalised light vector components to suit someone else's scene. Message2040202.txt needs to be renamed to RealSkinBody.mt5 to be recognised by P5.
Please scream at me if this is a no-no and I'll pull this post. :-)
Prefix-GeoffIX-Suffix
Message edited on: 12/11/2004 23:18
gwicks, firstly, the 3rd render is nice. A great "red" transitioning between the light and dark side of her thigh. The light side is too yellow IMO, and this is generally due to too much lighting in the scene. Real skin under heavy lighting goes very white, not yellow. Also, have you got the ambience incidence effect plugged in? The dark side of her thigh is too dark. Maybe wind the ambient red up a little. One of the weaknesses of this technique is that there is no ambient red on directly backfacing (to the main light) poly's. Will find a way around this one day.... On to your problem at hand. I had never seen the effects you are getting (although I don't use r/t shadows that often). One thought that comes to mind is that it's being caused by the displacement map. Try switching that off and see if it helps. Seems to be a shadow problem, so try depth-mapped shadows instead of r/t. Also try turning up the shadow min bias.
Creator
of OctaneRender
for Poser
Blog
Facebook
If the shadow bias doesn't fix it, this is due to the miniscule nature of poser's scene-space. basically, the shadows require too fine a calculation value in raytracing because they are too small. Try the shadow bias first, always, If it doesn't work, increase the total scale of all your objects in the scene, and it will vanish at about 10 times their current size. As for the shader work: Awesome work. thumbs up
Ah! Thanks face_off and ynsaen! I decided to do a bit of RTFM. Unfortunately, as usual, the P5 documentation is nothing more than a tease, hinting at answers but failing to provide them or a rational way of deducing them short of tedious trial and error. Can someone tell me what the value the render option "minimum displacement bounds" actually does. The manual implies it's measured in pixels, but that seems illogical. Mine seems to default to 0.000. I have "use displacement maps" checked (having tried disconnecting then reconnecting all the granite nodes from the displacement option in the root node for V3's material zones. Doing a test render now (tap foot. look at watch. repeat ad nauseam) with min displace bound set to 1.000! Will muck with shadow bias next render if that doesn't help. I already have my scene scaled up 10 times. I'll try 100 after that, lol. As far as the yellow tinge to the skin tones goes, I'll try setting the lights back to colourless greys.
I don't think I can add anything significant, other than I've had odd experiences when using displacement-map methods on figures. Every Poser human I've tried, from Posette to Aiko 3, will only accept a very slight dioplacement before polygons seem to vanish from the mesh, leaving those little patterns of black holes in the surface. On reflection, the mention of Firefly rounding errors could be part of the problem. The effect does seem to be worse on the newer figures, which have the smaller polygons. Aiko 3, currently free from Daz, is the only one of their hi-polygon unimesh figures I have.
Looking at the tutorial, that Displacement value may be just high enough to trigger these bad effects. I'll have to try this out. And I shall have to see how the Granite node setting interact. (Aiko 3 has the Spandex morphs to give cloth edges at wrists, ankles, and feet. allowing the creation of a catsuit as part of the figure. There is also a new material-zone arrangement to allow shorter sleeves and pant-legs, but without the morphs the result looks as though it was painted on. Feeding a displacement into the material for the clothed body-surface gives that edge, but can trigger the lost polygon effect.)
OK, there is a lot going on here....A couple of points (all based on my experience, rather than what might actually be factual). 1) If you have displacement bounds (FF setting) set the the displacement value in the mat room, you should get mesh breakage (unless the mat room node for displacement are passing a value of < 0 or > 1). In general, if you've got displacement bounds set correctly, any black spots will be caused by shadowing. 2) Min shadow bias....0 has always resulted in an object self shadowing itself in my renders. 0.3-0.4 seems to be the minimum level I can use to avoid this if I'm using displacement maps. 3) poly smoothing....IMO you should always have this on. It provides a true poly subdivisional surfacing, which should get rid of the sofa edge artifacts shown above. 4) AntoniaTiger....The effect you are getting above demonstrates one of the probs with displacement mapping in general (not specifically with Poser). It is not valid to simply plug white into a displacement map node. You need to build the displacement map in ZBrush, or another similar app - which will compensate for the poly edges in the map. Alternately, using a very low color or displacement value (as the RealSkinShaders does) gets around the issue.
Creator
of OctaneRender
for Poser
Blog
Facebook
Displacement in P5 is actually very flexible. There is a render in my gallery of a muscle-bound Don - which is all done with Displacement maps. Given my questionable modelling skills, the outcome isn't that good, but it proved the system. The trick is it get the right displacement maps.
Creator
of OctaneRender
for Poser
Blog
Facebook
AntoniaTiger, do a seach for "quinlor" in this forum. He posted a node setup for displacement mapping to get around the 8-to-16 bit colour issue.
Message edited on: 12/13/2004 15:07
Creator
of OctaneRender
for Poser
Blog
Facebook
Thanks for the pointer.
ZBrush looks to be seriously heavy-duty software, and a bit beyond my reach at the moment.
Raven, it looks like adjusting the Minimum Displacement Bounds fixes the effect I showed in that picture upthread.
Sorry, face_off, but I don't agree with you over the validity of just plugging a colour into the Displacement input. It's not well-explained, but all the shader nodes are effectively working on a UV map, and a simple colour node is effectively a single-pixel map. Using that colour, and tweaking the numeric value, seems to make the difference between something being painted on, and looking like close-fitting fabric. It gives you a physical edge on the body-surface.
It's a crude trick, but, now I've sorted the surface tearing, it works.
OK. More stuff learned the hard way. Without being finished with my testing and still not getting what I expect from displacement maps, I appear to be getting somewhat closer to the answers I need. Since my scene is all scaled up by 10 times (everything parented to a single room figure), it appears I have to multiply my displacement limits by 10 times as well! I do not have the Global Coordinates check boxes set on my displacement shader nodes, but I've had to set my minimum displacement limit to 10.0 with comparably large values on individual objects in order to render the round sofa with polygon smoothing and without the displacement clipping render artifacts. I still can't see any effect from the displacement shader itself yet, so I'm going to try boosting the scale of that next. This is getting painful. Flexible, I'll grant you, but painful nevertheless :-)
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=856238&Start=1&Artist=slinger&ByArtist=Yes
I just wanted to say thanks for a great tutorial. It does look a bit daunting to start with, but it's definitely worth the concentration required ;) Here's how it turned out for me. http://www.renderosity.com/viewed.ez?galleryid=856238&Start=1&Artist=slinger&ByArtist=YesThe liver is evil - It must be punished.
Nice one slinger :-)
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=859240
Must agree with slinger... It's worth it :-) If anyone's interested, here's my result http://www.renderosity.com/viewed.ez?galleryid=859240Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
Attached Link: http://www.users.on.net/~pkinnane/RealSkinShaderTutorial.html
Hi All Well after months and months of tinkering with nodes in the mat room to get more realistic skin, I've come to a point where I think I've taking it to where I'm comfortable with it, and it needs fresh ideas (ie. from other poeple). Also, I am spending more time on other projects. So I want to get what I've found out into the public domain. The link above directs you to a tutorial I have written on rendering (more) realistic skin in Poser. Enjoy.Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
