Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 26 12:28 pm)
Nope, but you could do the following: Save your own preferences and add them to a UI dot. Restore factory settings, then save the light set out to the Lights library. Restore your own preferences from the UI dot.
I kind of figured I should try just saving the default light set before posting this. :D I wasn't aware that loading the default lights would delete all the existing lights, although I knew it was a possibility. I'm curious though, why would I need to do all the rest? Can't I just open Poser, save the lights, and use that set whenever I want to return to default lighting?
The reason I suggested all of the above was in case you used a heavily customised Poser workspace with a weird light setup. That way, you wouldn't lose your own settings when you revert to factory settings. Glad you got the light set, anyhow.
I could've sworn I saw a freebie here that deletes all lights and restores default P5 lights, but I can't find it. Does anyone know where I could find this?
