Fri, Jan 10, 7:00 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Wet Ground
Robo2010 ( ) posted Sat, 11 December 2004 at 9:17 AM · edited Sat, 03 August 2024 at 5:25 PM
Since we can make mirror reflection in P5, using ground. I was wondering if it is possible to make a wet ground, using the reflection? Has anyone done this?
compiler ( ) posted Sat, 11 December 2004 at 10:16 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=798100&Start=1&Artist=compiler&ByArtist=Yes
In this pic, I tried to make a SF pavement : ultrasmooth, and wet. I'll leave it to you to judge wether I succeeded...
maxxxmodelz ( ) posted Sat, 11 December 2004 at 10:54 AM
Attached Link: http://www.evermotion.org/tutorials/particles/rain/
In this tutorial (which was made for 3dsmax) there are some excellent "wet" maps that can be used in Poser as well to test the results. Its an excellent example of a highly realistic "wet" ground material. He offers the 3ds scene files for download, and the maps themselves can be downloaded seperately for you to run tests with. You can't use them commercially of course, but you can use his maps as a reference to make your own reflection maps in photoshop that simulate the effect as seen in that tutorial, right in Poser. Creating the "rain" (if you wanted to) would be another issue, but Poser can probably simulate that too using the Metaparticles plugin. This example shows a "ripple and splash" effect from the rain hitting the ground, but you can use it's basic reflection map principles to produce any kind of wet surface effect. It's just a matter of creating a greyscale map of the ground surface that you plug into the reflection node of the ground material, telling it what parts of the ground are more "wet" than others. Using this map in the bump node as well should produce a great wet effect.
Robo2010 ( ) posted Sat, 11 December 2004 at 9:52 PM
maxxmodelz...that link sure got me going. Been on this wet floor thing since 8:00am this morning and now it is 8:50pm. I am trying and trying techniques and new ones I never thought off. In this pic, I gave the rain a try, although we are not going to see rain in poser.
Robo2010 ( ) posted Sat, 11 December 2004 at 9:53 PM
Here is another one. What I am looking for is glossy effect (Wet). I am still working on this.
maxxxmodelz ( ) posted Sat, 11 December 2004 at 10:22 PM · edited Sat, 11 December 2004 at 10:24 PM
That's actually looking pretty damn good. Are you using displacement or bump maps? I can't tell if you have a texture in the diffuse node, but whatever the surface is that you want to achieve, put a diffuse map in there (like a concrete map, or whatever). Then, plug the same texture that's in your diffuse node to your bump or displacement node (your choice), or make your own seperate bump map in photoshop using greyscale tones. Then, use the same texture you have for your reflection map, and plug that one into whatever node you DIDN'T plug the diffuse/bump map into... for instance, if your diffuse map is also plugged into the bump node, then try plugging the reflect map into the displacment node, or vice versa, to "mix" the surface complexity, and give the impression that the water has a different texture and actually rests on top of the ground surface. If you know how to use math nodes or any of the advanced nodes in the material room, they could do the same effect, and probably be even more useful for this.
Play with the intensities of both the bump node and displacement node, and make sure you render in Firefly with displacement enabled in the render settings. Don't go too heavy on the displacement or bump value, but try different things.
The point of this would be to make the ground look more wet in some areas (like areas on the gound where water has collected in small puddles or pools), and slightly less wet in others (where it's surface would just be shiny from the wetness, but no water has actually accumulated). Of course, this would only apply if the ground surface you are trying to represent is not supposed to be completely flat... surfaces like concrete or pavement are never completely flat and smooth, so water builds up in some spots, but not in others.
Good luck testing the different techniques. Let me know how it progresses.
Message edited on: 12/11/2004 22:24
Robo2010 ( ) posted Sun, 12 December 2004 at 12:56 AM · edited Sun, 12 December 2004 at 1:04 AM
I took an image from a file that I was able to download "Maps" file. And inside is this one texture. For me when ever I use an image. I take that image and make another one, by using Negative in PSP8. Then the Negative image is connected as a bump map. The image file Nod strength is 0.50000 and in the bump is -1.000. I notice when I do that. I get a really kewl effect. I keep playing around. Sometimes making my own textures and having one more as a negative, using a Bump map. I have problems changing the extension .jpg to .bum in Windows Explorer. So, I just use the jpg as a bump image. I am not using the ripple image and negative for now. Trying difference techniques without, and with images. Still figuring it out.
I think their is a bug in Transparency. Soon as I select it and use 1.0000 as a value. My CPU temp increases. I had the computer shut off by itself from overheating (Turn off a this temp). I have a AMD Athlon 3200XP+, with 2GB of DDr Ram (PC3200's duel channel, at 400mhz), 128 mb Radeon 9600xt, 80GB HD (7200 RPM), and poser doesn't perform like I would like it to (Or it should). I wonder if CL is working on another patch for P5? I couldn't see them come out with P6 and leaving P5 users with buggy software. That will be totally bad service to the customers.
Can you see image above has a gloss effect on ground? Looks wet, but this is not what I am looking for although it still needs adjustments. Still trying.
Message edited on: 12/12/2004 01:04
Robo2010 ( ) posted Sun, 12 December 2004 at 1:17 AM
Taking a image, then turning it into a Negative, and then using it as a Bump map. This is the results.
Robo2010 ( ) posted Sun, 12 December 2004 at 1:18 AM
This is the Nod settings.
Robo2010 ( ) posted Sun, 12 December 2004 at 1:40 AM
Getting Close, nearly 1:00Am here now.
Robo2010 ( ) posted Sun, 12 December 2004 at 1:51 AM · edited Sun, 12 December 2004 at 1:53 AM
Yup..getting closer. I had goosebumps when I saw the results of this one. :-)
Message edited on: 12/12/2004 01:53
Robo2010 ( ) posted Sun, 12 December 2004 at 2:28 AM
Did more adjustments. Think I can go to bed now. Will look at this again tomorrow or next day. Have things to do.
compiler ( ) posted Sun, 12 December 2004 at 4:33 AM
Wow, looks really great ! the only strange thing is that the reflected image seemd to be split in polygons. Any idea of what's causing this ?
maxxxmodelz ( ) posted Sun, 12 December 2004 at 11:00 AM · edited Sun, 12 December 2004 at 11:00 AM
Robo, I personally think the example you gave in post #8 looks the most like real wet pavement. It looks extremely good. IMHO, the examples given after that one appear more like the car is standing on water. The first one (post #7) looks good, but not like wet pavement. Looks more like marble.
I think you nailed the look on post #8 honestly. :-) But that's just my opinion, you know what you're after.
Message edited on: 12/12/2004 11:00
Robo2010 ( ) posted Sun, 12 December 2004 at 1:05 PM
I like Post #8 as well. I am keeping that one to. :-) That is why I also posted the nod settings. Although that is not what I am looking for. Trying for that real glossy ground, wet with waves. "Shiny" Like Post #11. See in post #11 That is what I like, the ground really wet, but I am having a problem with the reflection. Lower part of the vehicle looks ok, although the top part doesn't look right. So in Post #12, looks better, but still problems. I will post my nods later.
Gareee ( ) posted Sun, 12 December 2004 at 10:19 PM
Robo2010 ( ) posted Sun, 12 December 2004 at 10:50 PM
Ok..the more I do this, the more I lose my imagination what I am looking for. I guess I have to go out and make photographs with my digital camera to see what I am looking for, grasp that imagination again. Although this could be the one I am looking for. But I came to this image (273 Renders later in two days). What do you think? I can make a tutorial. I made my own textures, except for one.
hauksdottir ( ) posted Mon, 13 December 2004 at 6:41 AM
A tutorial would be great... it looks like you've grounds for one. ;^) Carolly
msg24_7 ( ) posted Sun, 19 December 2004 at 11:44 AM
This is a great thread :) It did help a lot in finishing my latest image... For anyone who's interested... http://www.renderosity.com/viewed.ez?galleryid=838237 Now, I'll have to find a way to create convincing rain and get more realistic waterdrops. And postwork is not an option ;-)
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
Gareee ( ) posted Sun, 19 December 2004 at 11:52 AM
That is killer! How about posting the material node for your rain ground?
msg24_7 ( ) posted Sun, 19 December 2004 at 12:46 PM
Sure, no problem... here is a screen shot of the material node for the ground... I did start of the way Maxxx mentioned in post 6
I am not quite sure if plugging the reflect node into the Translucence channel
really has any effect or if I am just seeing things :))
msg24_7 ( ) posted Sun, 19 December 2004 at 12:48 PM
Oh, and the "rainmap" is the one from the link in post #3!
Gareee ( ) posted Sun, 19 December 2004 at 1:32 PM
Thanks! I had missed that link in post 3, so I snaged that as well now. The more new things people come up with for P5, the more it really amazes me. I wonder if CL even had a clue about the power of these material setting options?
Gareee ( ) posted Sun, 19 December 2004 at 1:34 PM
BTW, Robo, I prefer the wet ground in post #12 personally.. it looks like something you would see in a car commercial..
Robo2010 ( ) posted Mon, 20 December 2004 at 3:17 AM
Thank..I am getting prepared to make a quick Tutorial. :-) Their is so much in Poser we are unaware of. After playing around in the nods, and making my own props.
