Tue, Jan 14, 1:16 AM CST
Subject: Poser to bryce question...
Azrael00023 ( ) posted Sat, 11 December 2004 at 2:05 PM · edited Sun, 12 January 2025 at 8:57 PM
I have poser 4 and Bryce 5, but I would like to bring Poser characters over to brcye and add background. Do I need a plugin for this? If not how do I import a character?
draculaz ( ) posted Sat, 11 December 2004 at 2:28 PM
there is a plugin for daz bryce, and i think that you can get it from the daz3d.com site (for free? not sure...). Anyway, you don't really need it, what you need is to export your poser person as OBJ, after which you can import them into Bryce (File: Import). Then it gets a little tricky. Ideally once your OBJ is done importing, it should ask you for the textures. The tricky part is that if your figure is clothed, you will have to ungroup the object. The clothes are separate, everything except the head is separate, the head is separate, and I think the eyes are separate. Eyelashes also need blend transparency settings. There are some tuts out online on this issue, I strongly advise you look them up. Drac (perennial poser hater) ((WHY DO I KNOW ALL THIS??? WHY????))
RodsArt ( ) posted Sat, 11 December 2004 at 2:31 PM · edited Sat, 11 December 2004 at 2:34 PM
Attached Link: http://www.rochr.com/
Export your Poser model as an .obj file to a floder that you're storing the bryce file in. I create seperate folders for each piece of work I do, Like a library.
Open Bryce, select File / Import Object. Bryce will prompt you for the texture Map files.
You can use your windows Explorer to do a search or manually find them. (Directory structure as follows):
C:/ProgramFiles/MetaCreations/Poser4/Runtime/Textures
Then depending on the model there are many more Sub folders after Textures. That's why it's easier to do a search.
Once the Map/Textures are loaded, Go to Rochrs website at this link, go to: Tutorials/Poser to Bryce. This will give you better details.
Shout if you get stuck.
ICM
Message edited on: 12/11/2004 14:34
___
Ockham's razor- It's that simple
RodsArt ( ) posted Sat, 11 December 2004 at 2:33 PM
LOL, Cross'n the Drac...Who luvs Ya Baby!!
___
Sambucus ( ) posted Sat, 11 December 2004 at 5:57 PM
Or handle your textures the easy way and get Grouper from freestuff.
Azrael00023 ( ) posted Sat, 11 December 2004 at 5:59 PM
lol Im really confused now... So when i create an object in Poser to export, there are a bunch of options, like group, should I group?
RodsArt ( ) posted Sat, 11 December 2004 at 6:31 PM · edited Sat, 11 December 2004 at 6:34 PM
Ok this is the first part. Export from Poser. At the top of this Forum there's a "Chat"(No users in Chat) Meet me there if your browser will allow it. I need to ask a couple questions. If you can't get in, I'll start putting a TUT together. See you there ICM
Message edited on: 12/11/2004 18:34
___
Sambucus ( ) posted Sat, 11 December 2004 at 6:36 PM
Ok, first you export your object as a wavefront.obj into a new folder. Then come out of Poser and open Grouper. There are five tabs along the top. Click on the first one "Files". You browse to where you placed the .obj, click and thats the source file. The destination file field is best left alone as it will give you the same directory as the source. Now click on "Groups". Along the right side are more tabs. Click on scan. This will get all the materials used in your Obj. Then under map click save. Now go to the fourth tab, "Convert and Repair". In the first window browse to where you keep your Poser textures and click "Include". This can take some time but you only have to do it once Now click "Package" and when thats done,click "Convert"
What all this does is get a list of materials used and then makes a folder with the addresses of those materials.
In practice you import the .Obj and when it says a material cannot be found, it should open up the same folder window in which you saved the obj. Here you will also find a folder of the maps.
It sounds complicated but really it`s the work of seconds once you get used to it.
Hope this makes sense and is of help.
RodsArt ( ) posted Sat, 11 December 2004 at 6:41 PM
Oops my bad, didn't read it well enough. Didn't read you were already in Grouper. I don't use it. Sorry. Sams gotcha covered.
___
Sambucus ( ) posted Sat, 11 December 2004 at 6:57 PM
I dont think hes actually used Grouper yet, ICM. Its just an option I suggested. I think your screenshots could make it a little clearer for him than my babble. Id carry on with it. :o)
chohole ( ) posted Sun, 12 December 2004 at 2:40 AM
I know our Drac is a poserphobic, but in all he time I have been exporting poser figs to bryce I have never ungrouped them, never used grouper or any other app, and have never had any problems....now where am I going wrong.
The greatest part of wisdom is learning to develop  the ineffable genius of extracting the "neither here nor there" out of any situation...."
sackrat ( ) posted Sun, 12 December 2004 at 1:43 PM · edited Sun, 12 December 2004 at 1:44 PM
Actually,..........(someone may have said this already,..I'm just to old and lazy to thoroughly read all posts), I just export the figure from Poser to the folder where the figure textures are stored and viola', Bryce will atomatically apply the textures on import. Of course you have to adjust them by hand anyhow,......but still,......and I leave the figures grouped and use Control+right click"(I think)to pick sperate parts of the mod, then apply the texes. Generally, if the textures and exported model are in the same folder, you shouldn't have a problem. That's my story and I'm sticking to it ! This works for .obj files,.....I don't know about any other formats.
Message edited on: 12/12/2004 13:44
"Any club that would have me as a member is probably not worth joining" -Groucho Marx
